-   -   what is that thing of the day (http://forums.pelicanparts.com/porsche-911-technical-forum/173859-what-thing-day.html)
hpmad 07-22-2004 07:13 PM
Hello!
I have another what is that thing that I want to run past you.
at the left back of the engine, I have that a pipe which is disconnected and that I can not reconnect because the pipe it connects in is more or less dead.
Can someone identify this pipe, what it's doing, and what is going to be done wrong if it is not connected.
the car is a 1980 911 SC.
the pipe is located next to the connection for the o2 sensor (see picture)
http://hpmad.homeip.net/what%20is%20...s_IMGP2329.JPG
and is connected on the other side to the CIS/air box stuff (I do not know how to describe it better), but look at the picture (it's the air intake on the right).
http://hpmad.homeip.net/what%20is%20...s_IMGP2331.JPG
you can see better pictures at:
http://hpmad.homeip.net/what%20is%20that/big.html
Also, I created an easy o2 connect/disconnect stuff, see:
http://hpmad.homeip.net/what%20is%20...s_IMGP2332.JPG
Thanks, cyrille
AFJuvat 07-22-2004 07:40 PM
Looks sort of like the vacuum line for the brake booster
AFJuvat
oneblueyedog 07-22-2004 10:18 PM
It's either that or an emissions hose. See if it goes to the Charcoal canister.
oneblueyedog 07-22-2004 10:22 PM
If the hole goes into the airbox ( plastic protrusion from the airbox, not steel) it's an emissions hose to the Char Can.
hpmad 07-23-2004 05:58 AM
hello
so, what will happen if it is disconnected? beside the EPA going down upon me?
jdowty3 07-23-2004 06:19 AM
On my 83 SC, that port off the air box goes to a port on top of the cruise control tempomat in the corner between the firewall and the fuel accumulator. If it was open, it would be a considerable vacuum leak.
hpmad 07-23-2004 07:13 AM
hello
could that explain why the cruise control loses the speed when the engine warms up? and why the IDLE speed get higher and higher as the temperature goes up?
