rickeolis's Avatar
Porsche Crest Changing gear ratios on a 915?
I find I am not happy with the 8\31 ratio on my newer tranny. I am used to the stump pulling power of my previous 901 with its 7\31 ratio.
How involved is the changeover (putting a new ring and pinion into the 915) once I have my tranny out?
Costs?
-Rickeolis-
1986 Corvette
Old 07-23-2004, 10:48 AM
H20911's Avatar
You might be able to buy a used one for what it would cost to rework what you have. Look for a 74 trans it should have a TL 5th gear that will help easy highway cruising RPM
h20911's V8 Homepage
www.home.earthlink.net/~sdfranco/index.html
Old 07-23-2004, 11:35 AM
find a 76 912E trans which has an electric speedo, and use the complete 7:31 R+P and shims from it. it's a direct swap, no setup needed. be sure to get the drive flanges with it, as they are coarse splined and a 77 is fine splined. same outer flange shape/size.
206 637 4071
Old 07-23-2004, 12:46 PM
rpiper's Avatar
I did what John said and it saved me money vs. having to source a spacer and shims etc etc. It's a very good upgrade, and as long as things are apart I'd swap in a taller 5th too.
Bob Piper
78 911SC "Bullseye" SOLD
00 540i
02 CBR 954RR
98, 00, 03 sons
Old 07-23-2004, 02:46 PM
mm86911's Avatar
Excellent choice - my '86 3.2 screams through every gear! Great for track and autoX using 7.31 with stock trans gears.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 07-23-2004, 02:50 PM
rickeolis's Avatar
Porsche Crest
Alright! Now I know what to do, thanks!
I'd use my 901, but I hear they have issues as they get close to 200+ horsepower.
Noah, I did e-mail you, thanks!
-Rickeolis-
1986 Corvette
Old 07-23-2004, 03:07 PM
