-   -   engine numbers (http://forums.pelicanparts.com/porsche-911-technical-forum/173994-engine-numbers.html)
rkh3 07-23-2004 02:58 PM
engine numbers
Trying to determine the engine that is in my 79 911. The #s next to the fan are *6285832*. The numbers further in are 930/63.
Any ideas?
emcon5 07-23-2004 03:16 PM
Re: engine numbers
Any ideas?
Curious, they don't match.
According to my cheat sheet,
*6285832* is a 1978 (USA/CDN) 911 SC, engine type 930/04
930/63 is a 1978 or 1979 California Turbo, and the serial number should be 688xxxx or 698xxxx respectively.
Tom
svandamme 07-23-2004 03:33 PM
628xxxx is not an engine from California
it came out of a car with a Vin
9118200001-9118202436 ( that covers the chassis for US both 49 states +California)
only the engines are listed seperately, Calif engines are 658xxxx
where exactly do you see this 930/63??
rkh3 07-23-2004 04:17 PM
The 930/63 is on a flat surface directly behind the casting #, it is horizontal, as opposed to the other number which is vertical
rkh3 07-23-2004 04:20 PM
The VIN is 9119201999. Believe that is for a '79 911SC with a 3l engine
svandamme 07-23-2004 04:42 PM
911920xxxx :
911SC produced from august 78 till july 79
49 States should have engine number 629xxxx (930/04)
Californians should have engine nr 659xxx (930/06)
rkh3 07-23-2004 05:04 PM
The car is from CA, could it be a "mis-stamp"
emcon5 07-23-2004 06:07 PM
This is an engine swap, 3.3Turbo into a 79 911SC correct? The VIN isn't relevant.
Are you sure that "2" isn't a "9"? As in 698xxxx ?
Tom
rkh3 07-26-2004 05:28 PM
No, it is a "2"
