Contemplating powder coating my fan and fan housing . . .
either red or silver. Has anyone else done that? Any pics? Color ideas?
1989 911 Speedster 2006 Cayman S No one ever said on their deathbed, "I should have been more practical." |
F/S Very Sweet Fan Shroud
It has been done, as far as colors go, match your car's color scheme |
Wildman Emeritus
Al reed is supposed to be the man. Just make sure to have Al or whomever does the powdercoat to mask the ends od the fan blades. No mask = interference/rubbing= mess.
Don't ask how I know, but it will be corrected this winter.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Here's a pic of red powder coat.
"Never go faster than you can stop" 85 - 930 (750hp) Norwood motec 3.5 twin turbo |
http://www.headercoatings.com/
They only have 3 colors (white, black, and silver), but you can't beat their prices.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
I did red & black - done locally. Very few have had clearance issues - but you might be in that few....
I did mine in semi gloss black, looks like everything else in there.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
I polished mine myself, took about two hours.
Ted '77 911 Targa |
I strongly advise against painting the fan blade, either by powder coating or painting. The speed the fan is turning will eventually cause the leading edge of the blades to chip and then oxidize. Better to clean the fan once to polish and then let it accululate a matte finish that is maintenance free and acceptable. I've seen many a painted fan that is chipped up and look worse then when it started.
Here's mine!!
Jason F-15 Crew Chief (21 years) '86 944 '71 914 (Sold) '79 911 SC (Sold) |
Here is another red one
Rob, 88 911 Turbo |
Thanks guys, all great looks!
Regards, Wes
painted fan
I like what 89911 did. Looks AIRCRAFT.
What was the abrasive and final grit? Is there any clear coat or plate final step? |
I was sending my roll bar to the powder coater and figured I should pull out the fan and fan housing and send it along with the bar...easy right?? WRONG....
Removing everything wasn't a quick task....not hard just a pain in the a$$....once the fan, housing and alternator was pulled from the engine, I had a b$tch of a time getting the alternator out of the housing. During the removal process I ended up breaking one of the alternator brushes.....again not hard but a pain in the a$$...and about $75 replacement part. Was it worth it? Absolutely....just wanted to share with you my experience so that your task won't be as difficult. BTW...I powdercoated everything silver.....what a difference it makes in the engine bay appearance. Good luck!
It's not just the cars...It's the people... ![]() Porsche Club of America NoVa / DC / MD Porschephiles Porsche911FactoryTurbo-LookCars |
My car had a chipping coated fan. I used a lot of elbow grease to get it back down to bare mag so I could let it grow a beautiful and durable grey platina. As the following pic shows I have also taken the stainless exhaust down to bare metal so I can appreciate its golden hue once it heat cycles.
83 SC (gone) / 72 T (gone) |
I say Powdercoat it, I've never had any trouble with mine after almost 4 years. It's all in the prep work. I just wish I would have done the Fan Housing in Black to really contrast the fan. oh well, it's never too late.
Scott aka Mouse
Gruppe B #22 Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6 Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo Last edited by ScottKelly911; 07-23-2004 at 09:50 PM.. |
