Stuck Fuel Door
Fuel door won't release on my '72T. Tried to "pick" it but only succeeded in chipping paint. Cable doesn't sappear to be broken.
Advice / tips? TIA, Bill
Triplesn8s '72 911T Coupe - Resto Proceeding at a Snails Pace ‘80 TR8 Convert - SOLD '78 TR8 Coupe - Autocross Project '06 Ducati 1000SS/DS - ‘11 H-D XR1200x |
What?!?!
You may have already tried this but push down with one hand and pull handle with other. Or push down and then try to gently pry the latch.
Maybe someone that has had to deal with this problem in particular will sound off.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
Easy...get a length of stong nylon cord...run a loop of it through the door cut out, near the front, so you have the line UNDER the flap. Pull upwards and backwards...the line will catch the release, the lid will pop open. My flashlight carries a wrap of line on it's handle..."just in case".
Thanks a bunch, I'll try it tonight.
Bill
MY GOOF! JUST BACK FROM LOOKING AT MY FUEL DOOR! Apologies, but it has been a while since I've done this trick...start the line at the REAR of the flap opening, not the front. Hope you read this...BTW, Jensen Healy...cool ride!
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I figured out what you meant. Worked like a charm. Now I figure," Why fix it?". Just kidding.
The JH is supposed to become a EP SCCA car. Onset of fertility has delayed completion. Actually I just barely got the roll cage started (last year). I have some really neat Huffaker flared glass fenders though. They look great up in the rafters of my pole barn. Thanks again for the tip. Bill
Glad to help...definitely a memory soft spot here for Jensen Healy...just great lines and an engine that begged to be modded a bit!
