-   -   Fixing the rust question (http://forums.pelicanparts.com/porsche-911-technical-forum/174238-fixing-rust-question.html)
mracer2001 07-25-2004 02:34 PM
OK, I was enjoying the cool weather of this weekend and decided to do a small project of painting my wheels - the black paint on fuchs was very dull and in need of some refreshment. Well, to my surprise, I noticed that I am having soem rust problems on the bottom of the wheel cavity in the front of the car. it's on both front and rear corners of the front wheels - lieft and right. Needless to say it got me upset. After a few moments I said to myself that being sad about it won't fix the problem and so I decided to tackle it with all the energy in the world.
2 options that I have so far is to
1. do it myself in my garage - no welding machine there or...
2. take it to my mechanic and try to patch it there.
If I stay at home - what are my choices - what can be done? The rust is on the sides of the tub and so it's not a body panel that cn simply be changed... So what do i do?
mracer2001 07-25-2004 02:35 PM
Oh.. sorry for not clarifying but there are holes on each side of the front cavity - both left and right fronts. So it's not just surface rust.
svandamme 07-25-2004 03:20 PM
like this?
http://forums.pelicanparts.com/uploa...1090793987.jpg
irl 07-25-2004 08:20 PM
I have been doing some extensive rust repair on a 74. I have some great before and after photos that I need to scan and post because there is not enough rust repair articles here. I was a beginner 6 months ago and now I'm not scared of anything. The scary part is that you may have more rust than you realize once you start looking around. The first step is to get a small grinder and a wire cup brush and see how bad the areas are. I purchased a small 400.00 lincoln welder and several sheets of 18 and 20 guage steel and its been going real easy. And I must tell you I am a advertising exec not a mechanic. Also go to www.POR15.com and read about their products. Feel free to ask me any questions. Good Luck.
Zeke 07-25-2004 08:29 PM
Pictures! please.
1973911s 07-25-2004 08:34 PM
My car goes in Monday for rust repair in the drivers door jambs
Michael
mracer2001 07-25-2004 11:14 PM
svandamme - yeap, very simmilar... It looked like someone was trying to cover it/repair it with just bondo and underbody spray, but we all know how "helpfull" that usually is. Got me pretty upset, but i guess it's a lesson on a few levels here. Do a better pre sale inspection and it will teach me how to fight rust :)
I will post pics tomorrow, well, today in the morning as it is 2 am already! Hope to hear some good advises.
mracer2001 07-25-2004 11:17 PM
irl, i see we have simmilar tastes in cars - I got bmws and Porsche as well. As much as i love the 911, i really love the E30 M3.
svandamme 07-26-2004 12:04 AM
i took it to a body shop ( two old fella's with a passion for cars, they do full restaurations of cars , even ones from before the second World War), he had it welded with stainless steel
took him no less than half a day per side ( i did all the stripping) not counting the lifting of the car and stuff
he did cut everything out, and make new supports on the inside..drain holes,new edge , beating the stuff in to a form that fits the car... magic stuff
http://forums.pelicanparts.com/uploa...1090825369.jpg
http://forums.pelicanparts.com/uploa...1090825445.jpg
finished work :
http://forums.pelicanparts.com/uploa...1090825723.jpg
don't have a better pic of the round part with me, but you can't see it was ever welded...the only thing i can see is the thick welds from the PO on the floor pan
mracer2001 07-26-2004 09:39 AM
wow, i can't even imagine how much that job cost!
svandamme 07-26-2004 10:02 AM
eeh , the biggest cost was for the painting
the guy charged something like 25 bucks an hour
but he did the welding in 16 hours
so 400 bucks for the welding ...
maybe another 100 for the new undercoating
all things considered, i don't think that's much for a job well done
but i did all the stripping myself,
spent 2-3 months of dissassembling and stripping
only in weekends since the car was in a garage 30 miles from my house...that saved me a lot of money...
mracer2001 07-26-2004 03:25 PM
Well, i thought it was going to be much more then that.
Sounds like a great deal!
Here are pics of what I am facing, or atleast what I found so far.http://forums.pelicanparts.com/uploa...1090880416.jpg http://forums.pelicanparts.com/uploa...1090880518.jpg http://forums.pelicanparts.com/uploa...1090880702.jpg
svandamme 07-26-2004 03:38 PM
step 1
stripper, and like Steve Wilkinson says in his book
"not the female kind"
eat the coating away , and see what you got
could be more , could be less than what you see
2
get it welded ( and cut away liberally , a bigger patch is better+ it allows inspection of what is behind it )
from the looks of it , it's going to be pretty doable , it doesn't seem to be in a spot where different panels join, but you won't know for sure till you've done step 1
mine was mainly at the edges, and right in the round part... all the way right up to the brake line
step 3
new antirust stuff, and coating
if you're not going to do the welding yourself , i would suggest taking it to a shop (or several) first, ask them what they think , if they can weld with the fender in place
i took everything off, because i didn't know what else i had , rust wise
but mine is older , and the rust signs where more obvious...
yours migt be doable witht the rust in place, dunno , depends on whoever does the welding
if they can tilt the car sideways enough, they can probably access those spot pretty good...
mracer2001 07-26-2004 03:46 PM
how hard is it to remove the panel? it's bolted, right?
mracer2001 07-26-2004 04:17 PM
Hey Ed, I sent you an email but not sure if you got it or not. So here is my question again. I went to the POR site and their products sound great. Which ones did you use and how do you feel about it?
Formerly Steve Wilkinson 07-26-2004 04:22 PM
Rust Never Sleeps.
You can delay it, you can cover it up, you can hide it, and POR products are wonderful at all the above, but if you don't replace it with new metal, it's like having prostrate cancer and choosing a "watchful waiting" strategy.
Stephan
mracer2001 07-26-2004 04:31 PM
yes, of course, new metal is a sure way to go. I will do some clean up and see how much of it i really need.
Formerly Steve Wilkinson 07-26-2004 06:21 PM
Did I actually write "prostrate" cancer? And I've had it. Shows you how much writers know about spelling...
Stephan
Zeke 07-26-2004 06:42 PM
Well, you might get prostrate cancer from lying on the floor and working on that part of the car. :D
The rust on racer's car looks minor comparably speaking. I wouldn't fret about it. If ou can get it fixed reasonably, great. Otherwise, wait for a slow time at the bodyshop.
irl 07-26-2004 09:30 PM
I don't know guys, but the front well piece could be the front pan and support going under the battery. What does it look like from the inside. I would get a cup brush and start ripping offf the coating. The good part is these are all the usual spots and many on this board can give you advice on them. The bottom line is, they must be cleaned out and new metal welded back on.
The POR products are for once the repairs are done. They have a gunky anti rust product that is just like the POR15 paint but its thicker and covers weld seams before you spray rubber coating back on to give it a smoother finish. I use them to protect the new welded area, not cover up rust.
svandamme 07-26-2004 11:33 PM
yes and no
there's also some nasty glue involved
and several years of dirt
it's tricky, could damage the paint in the process of removing
mine needed a respray anyway , if yours if fine, and the welder can do it with the panel in place... go that way... will save you time and money... ask a welder...
khyden 07-27-2004 01:48 AM
Rust
I did this:http://forums.pelicanparts.com/uploa...1090917935.jpg http://forums.pelicanparts.com/uploa...1090918007.jpg http://forums.pelicanparts.com/uploa...1090918064.jpg
khyden 07-27-2004 02:00 AM
Have done some 150 hrs of welding and metal work on the car, which is a -74 now with 3.2 engine and big power assisted brakes. Not a testdrive yet, but brakes are working and now it is time for the interia. Will do original now and during next winter put in the new seats and harness. Dumpers all around will also be changed next winter. Just have to get a drive soon....
Kris
mracer2001 07-27-2004 08:58 AM
Jeez khyden, that's a huge job and a bit too involved for me - well, atleast I wasn't thinking of getting so involved. Droping a 3.2 in sounds like a logical thing to do - you already had most of the car apart :)
Oh and I am not sure about the prostrate cancer, but I already got the frostrate cancer for sure! Part of the reason is that I just got done with another project of mine - 87 VW GTI. Fixed floor rust, painted, got the "period" Recaro seats, about to do a bigger cam, springs, lifters... etc. Next is m E30 M3 that can use new paint although everyone tells me how great it looks, but i can see stuff that they can't :) And so I hoped that my 911 was in good shape and just to keep it from beeing jealous I decided to spray the wheels with a new black paint to freshen it up - and of course I started to poke around... :( Now i got 3 projects!!!!! I better leave my 325IX alone - who knows what I will find there! ( I kinda just got done droping new tranny in it!)
mracer2001 07-27-2004 09:19 AM
here is what I am talking about...
From this...http://forums.pelicanparts.com/uploa...1090944080.jpg
http://forums.pelicanparts.com/uploa...1090944124.jpg
..to this
http://forums.pelicanparts.com/uploa...1090944836.jpg
http://forums.pelicanparts.com/uploa...1090944897.jpg
next in line
http://forums.pelicanparts.com/uploa...1090945087.jpg http://forums.pelicanparts.com/uploa...1090945117.jpg
Glasgow 911SC 07-27-2004 12:30 PM
So many of the rust pictures we see on this forum would have been less problomatic if Porsche had used fender liners. The amount of crud that gets tossed up there is scary.
Usefull Link Number 169
mracer2001 07-27-2004 04:30 PM
It never occured to me, but it does make sense.
