-   -   When to replace ball Joints? (http://forums.pelicanparts.com/porsche-911-technical-forum/174280-when-replace-ball-joints.html)
zzwhm 07-25-2004 06:01 PM
I've got the a-arms off my 87 Carrera to put on Elephant Racing poly-bronze bushings and wondering if I should replace the ball joints "while I'm in there". They look fine and there's no driving problem - how do you know if a ball joint has reached it's end?
Bill
mtelliott 07-26-2004 07:46 AM
I don't know but when I asked the shop while it was on the lift he got underneath it, pushed the wheel up and down, inspected the ball joint, and said it was fine. I guess they start to get spongy when they go bad.
To tell you the truth, I still don't know how to tell but if he said they are good, then I trust his opinion.
Neilk 07-26-2004 08:10 AM
Bill,
Do you have a ball joint socket I could borrow? I am trying to figure out how to remove the ball joint from the strut, they're stuck.
John Brandt 07-26-2004 08:13 AM
if you can gey them to wiggle around, they're done
I asked my mechanic about this recently. He said that he can only remember replacing 1 set of 911 balljoints in 20 some years. he said if you don't drive a 928 you shouldn't worry too much about them
jpachard 07-26-2004 08:22 AM
I change mine every year but this is on a track car. It sees 20+ track days a year. If a ball joint fails its pretty ugly.
James
