Electric window down, dead, now back to life
'88 Cab. Clifford Alarm.
The passenger side elec window was DOA after an evening event. Both the driver's and passenger side switches were dead. (I had a brief moment a few days ago when the same window failed before but it came back to life shortly after) I got home and immediately began debugging. I pulled the driver's and passenger switches, wiggled all connections. No dice. I tested continuity between driver's and passenger sides. All good. I finally pulled all the blade connectors off the passenger's side and reconnected. The window suddenly worked fine. I was pooped given it was now morning so I called it "fixed" and hit the hay. But this miraculous fix seems odd to me. I would have thought the wiggling, resetting of the blade connectors while power was on and the switch pushed would have triggered the window motor a little. Nothing. When it decided to work, it worked perfectly. I continue to believe the Clifford Alarm is the root of all things bad electrically. I find the alarm to be a mysterious thing which makes me uncomfortable in this car where I am beginning to gain confidence in self maintenace and repair. Could someone please offer thoughts and advise on this window thing? I'd love to fix it for good. Thanks.
CWL '88 Carrera Cab |
The same thing happened to me last week. The wndow switch had been working intermitently over the last few weeks. Finally last week it completely stopped working.
These switches are well known to fail. I just bought another one and the problem was solved. Be careful when installing a new one not to plug the wires incorrectly (I blew a fuse). There is a post somewhere in Pelican showing the right connections. |
If it is a switch and not some electric demon in the car (and in this alarm from hell), that is a beautiful thing. Maybe I'll get a couple in order to have a spare.
Are all three window switches identical?
Yes, the part number is 911-613-621-03.
However my new switch has a slightly different appearance than the old ones (not noticeable from 1 foot away). Do a search and you'll find that these switches are very prone to failure. |
The other possible cause of this is a sticky switch.. If the switch gets stuck in the ON position, going up or down, the motor overheats and a thermal cutout on the motor opens and prevents it from burning up. Re-centering the switch and letting the window motor cool cure the problem.
Dave '77 911S Rochester, NY |
That's very good to know. Still sounds like the switch should be replaced.
Thanks.
Also check for ground connections.
Martin |
Martin or anyone,
Where, in the wiring for the electric windows, would the ground connection for the windows/control switches be made? I don't even know where to start looking. Thanks.
Chris-
another potential culprit could be the fuse. both of my windows stopped working one day, so I checked the fuse, which looked fine and cleaned the contacts at the fuse box. still no windows. installed a new fuse - windows work. go figure.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
The power windows are another case of electrical system 'malpractice' by the Porsche factory engineers!!! Every other mfr uses relays to control motor power, yet Porsche used the door switches! It isn't any wonder that they fail regularly!
Anyone out there interested in a relay upgrade kit?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren,
So to be increasingly stupid on this topic... What is the relay upgrade kit and is this something I need?
I have a feeling there is the relay kit is another haloturbotronic molycasovic converter like solution. I fall for this all the time.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Maybe there is such a relay upgrade kit... but I've order some new switches for now.
Thanks.
Update:
After replacing the driver's door switch, the periodic power failure to the passenger window continued. Replaced the passenger door switch and, so far, all is well.
Steering Wheel Play
No I'm not playing with the steering wheel (930 type that's been on the car for 7 years). I'm getting some play in the steering. Its about a quarter inch or so from side to side while stopped. I can't feel it while driving but just barely noticible while sitting still and moving the wheel from right to left and back. Any ideas would be appreciated before I take my car into the shop. I keep getting this image of the wheel coming off in my hands while driving down I-10 and handing it to my wife telling her, "here you drive if you don't like the way I do it.".
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Re: Steering Wheel Play
Pelican has the metal replacement bushing.. then yank the wheel and insert. The old bushing can be removed if possible, otherwise just push it down using the new metal bushing. Use axle grease.
