Metal Fabrication Question
Hi Folks -
I have recently deleted the A/C from my '87 coupe.
Does anyone sell, make, or are willing to make a block off plate for the gap left by the front blower (the part behind the front bumper)?
Thanks.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 07-25-2004, 11:38 AM
Anyone want to make one?
I have money waiting for a pro job.
Old 07-25-2004, 12:48 PM
I would rather be driving
jpnovak's Avatar
Got a picture or a scale drawing?
Old 07-25-2004, 01:26 PM
Here are some pics...
The plate would need to be 6.5" by 4.5" .
One would need to measure the screw positions on an actual blower or make those oval slider holes....
I am looking for something light, black, rustproof, quickly done and factory looking.
Oh, and maybe a gasket of some sort?
Old 07-25-2004, 01:46 PM
J Smith's Avatar
Home Depot sheet metal worked fine for me. I sprayed the bottom exposed area with black Rustoleum. I also used some foam weatherstripping for a nice seal. Here's a pic (not a great one though)
It really easy to do yourself....just make sure you wear gloves if you're using a belt sander, or you could end up at the emergency center on a Saturday morning geting 6 stitches...ask me how I know. ooooooohhhhhh yeah, sheet metal cuts deep.
Josh
'87 911 Carrera 3.2 Coupe
Old 07-25-2004, 04:34 PM
You can also use Alu. sheet and a rivet gun
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-25-2004, 06:48 PM
Josh - That is what I am looking for, but I don't have access to the tools....
Wanna make one for me?
Old 07-25-2004, 09:53 PM
klaucke's Avatar
I can make you one, however you like: aluminum, stainless, or mild steel. PM dimensions. I can use slightly larger holes and you can use a small washer on each screw to allow for tolerences and adjustment.
Old 07-25-2004, 09:57 PM
