gar gar is offline
gar's Avatar
convert headlight washers to clean the rear of a turn signal housing
Can anybody help me diagnose the following problem:
Whenever I hit the headlight washer button, fluid puddles up and squirts out from behind the passenger side blinker.
Old 07-26-2004, 12:39 PM
echrisconnor's Avatar
You may want to try a different blinker fluid (I couldn't resist that one). Check your muffler bearings too.
Seriously though, shounds like the hose from your washer pump has a break in it back behind the blinker. Go trace the lines and look for where it's spilling out. There's a fitting from the big line off the washer pump which can come loose. It may be easiest to check out when the front valence is removed. Jack up the front first and see if you can reach in there from below.
'76 911 Carrera 3.0
Old 07-26-2004, 12:46 PM
jdowty3's Avatar
sounds like a split hose
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Somewhere in 53-59 lies your problem.
'76 911 Carrera 3.0
Old 07-26-2004, 12:53 PM
gar gar is offline
gar's Avatar
Well, it can't be the muffler bearings, because the post purchase inspection that I wisely sprung for (why get a pre-purchase inspection and pay good money to help someone else discover their problems?) that they were in top shape.
What really sucked was how expensive it was to change the coolant.
Old 07-26-2004, 01:18 PM
