"Baggy" gearbox/linkage any quick fix ideas?
is there a quick remedy to tighten up the play in a baggy gearbox. not really the gearbox but the play in the lever. seems like it should be way tighter. is it the linkage? new bushes???
thanks
1968 911L
1970 911E
Old 11-22-2008, 12:43 AM
Free minder
Aurel's Avatar
Yes and yes. Note that the shifter is not gated nor spring loaded, so it will always have that sloppy feel to it. The remedy to that is to replace the whole shifter assembly with a gated one such as the wevo shifter. But new bushings and linkage are the place to start.
First, read this tech article:
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
Then, spend 22 bucks...
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_Tshift_pg1.htm#item0
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-22-2008, 03:24 AM
jwetering's Avatar
WEVO are nice - really nice, but expensive.
Replacing the bush at the bottom of the shift lever, the one along the shift rod, and maybe the coupling will make it fell 158 times better.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 11-22-2008, 04:06 AM
