-   -   Idle trouble - Time to fess up... (http://forums.pelicanparts.com/porsche-911-technical-forum/174477-idle-trouble-time-fess-up.html)
ZOA NOM 07-26-2004 03:26 PM
I have to cleanse my conscience, and let you in on my bonehead move.
I have been grappling with a "hunting" idle for three weeks now, and it seems that a very simple mistake has resulted in more learning than I had bargained on. The good news is that just about every potential area of concern has been renewed, replaced, or confirmed good. I have a refurbished Air Flow Meter ($350), a new Idle Control Valve ($100), all new sensors (Reference, speed, Head temp, O2, TDC), replaced just about every clamp on every hose, all to no avail.
Today, I took the car to the mechanic to have him reconfirm the CO readings following the installation of the refurbished AFM, and he says, "The arrow on the ICV should be pointing the other way, no?"
All this time, the valve had been installed backwards, and neither he nor I ever noticed until today. I quickly swap it around this morning, and head home to let her cool down before starting her up "cold".
Turned the key, fires right up, idles rises to around 1100... and sits there like she's supposed to. After she warms a little, the idle drops into the 800-900 range and steady as a rock.
Unbelievable.
Doug Steinel 07-26-2004 03:39 PM
Hope you rkept all of the old parts. Evidently, they are all good. Now you have some backups. I love having backups on the shelf. Not running right? No problemo, just pull a part off the shelf and plug it in. I have a whole CIS system on the shelf, fuel pump, alternator, MSD box, cap and rotor, etc.
ZOA NOM 07-26-2004 04:19 PM
Definitely. Spare parts bin is full.
Paulporsche 07-26-2004 04:28 PM
Congratulations on your fix. Sorry to hear it cost so much in parts. Like the others said, now you have spares, or you've got some swap meet items.
ZOA NOM 07-26-2004 09:40 PM
I'm just happy to be idling smooth. It was driving me nuts.
djmcmath 07-26-2004 09:44 PM
Boy, most people have to go to a real college to get an education that expensive. Is that considered a "self study" program? :)
ZOA NOM 07-26-2004 10:01 PM
Tell me about it. It could have been worse, I was on the verge of ordering a DME.
Purrybonker 07-27-2004 08:16 AM
Holy crap! You mean it's not supposed to point up?
vash 07-27-2004 08:47 AM
rick, so i assume you may be ready for a sunday morning drive? or maybe an autoX? good job on the fix. you definately need to break a few eggs to make an omlette. in your case, looks like you went back to the store bought a few more eggs, and still ended up with an 3-egg omlette :) i have done the same. starter, WUR both come to mind. but i sold them both, CHEAP. oh, i kept the extra clutch cable.
cliff
ZOA NOM 07-27-2004 11:55 AM
Purry, nope. Arrow down, label facing you.
THIS JUST IN:
Still hunting at cold startup. Not as severe, but I am losing my mind. Going to try swapping a DME to see if mine is screwed up. Stay tuned.
Carl_Boehme 07-27-2004 01:17 PM
I know that you have replaced it but it sounds like the O2 sensor to me. Or, if its a three wire then the O2 heater controller. Actually if it is the controller I believe the idle would improve after the sensor heats up.
Good Luck
Steve W 07-27-2004 01:44 PM
check your idle mixture, and make sure the base idle speed is set correctly. Assuming you fixed all air leaks, you may have a worn ISV.
ZOA NOM 07-27-2004 01:56 PM
Thanks for the input, guys.
I think the idle speed, mixture settings may be involved. With all the adjusting and replacing, I have no baseline anymore. My mech loaned me a propane bottle with a hose outlet to use for finding vacuum leaks, and when I released some into the intake, it nearly stalled, when it should have increased the idle. This was with the motor warm, and not "hunting". He wants me to let it cool and try it again cold, while it's hunting. The AFM is newly refurbished, and the CO adjustment is whatever they left it at, and sealed.
I think I'm getting closer. It sure runs great when it's warm, though.
Steve, I replaced the Idle Control Valve (ICV). Is that also known as the ISV?
Doug Steinel 07-27-2004 02:08 PM
If it runs great when its warm there is a simple solution... never turn it off.
Steve W 07-27-2004 02:11 PM
Idle hunts when cold because whatever the idle mixture is at, and whatever the idle speed is adjusted to at the throttle body does not match what the DME wants to see, which is Lambda=1 and 880 rpm. So it hunts trying to adjust to it, but the latency of mechanical parts and oscillating feedback from the rpm and O2 sensors causes a hunting oscillaition until the engine warms up.
ISV, IAC, ICV, it's all the same.
ZOA NOM 07-27-2004 02:20 PM
Thanks Doug, already considered that, but I can't afford the gas!
Steve, it seems that swaping my DME would easily isolate the issue. Doesn't the DME "ignore" sensors initially at startup, running in a "closed loop" until it warms enough to trust the readings? If this is the case, it would seem that the "closed loop" outputs from the DME would be the most likely culprit since I'm only hunting when cold.
Carl_Boehme 07-27-2004 04:04 PM
The propane bottle is a huge fire hazard. You can accomplish the same thing with a spray bottle full of water.
A quick way to check for a vacuum leak is to remove the Oil filler cap with the car running. If there aren't any leaks the idle should slow when you remove the cap
ZOA NOM 07-27-2004 04:18 PM
Thanks, Carl
I was very conservative with the propane, and expressed those same concerens to my mech, who showed me how he uses it, and made me feel comfortable using it.
The idle slows when the cap is removed, so I am looking more closely at the mixture.
Steve W 07-27-2004 05:17 PM
You said your ISV was installed reverse right? Again, you still need to check and adjust the base idle speed and idle fuel mixture.
ZOA NOM 07-27-2004 05:21 PM
Right, it was reversed. The AFM was removed and sent away to be refurbished. It came back with the CO adjustment screw sealed, so no CO adjustment has ben made with it installed on the car. I am dropping the car off for my mech to hook up to the gas analyzer for an accurate CO adjustment.
Thanks for your help.
