Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
A place to rebuild Zenith Carbs
I've tried rebuilding zenith carbs myself, can't get them right, getting alot of popping back thru the tops and some of my jets aren't going and just finally want them right.
Anyone one know of anywhere that really knows these carbs inside out that i could ship or bring these to? I'm in suburban Minneapolis right now, but am willing to ship the carbs out to a good reputible shop.
I would like to try this route before i go and drop a bundle on webers. Also if anyone would want these carbs?? i'm willing to trade or sell, they work just need tuning that i don't know how to do.
Thanks,
Joe
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 05-18-2005, 10:14 AM
jluetjen's Avatar
You can call Matt at Eurometrix and see if he can do anything to help. Are your throttle shafts tight? To put differently, if you wiggle the shafts at idle, does the idle change at all?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-18-2005, 10:23 AM
Longhoods Unite!
thank ya sir, waiting for an email back.
Old 05-18-2005, 10:31 AM
Chuck Moreland's Avatar
Try Johns Fuel System and Carburetion 510 786 2505
Tell him I sent ya
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-18-2005, 10:47 AM
I currently have my carbs at Bieker Engineering, Harry seems to really know his carbs. www.biekerengineering.com
Old 05-18-2005, 10:53 AM
Longhoods Unite!
is there anywhere that will rebuild these for less than 700-750??? plus a big phat bump-a-lumper
Old 05-18-2005, 07:14 PM
jluetjen's Avatar
You can do them yourself. The folks on the BBS will be happy to help and the rebuild kit isn't that much. The key thing is to judge the condition of the bodies. If the shafts or the bushings are worn, no amount of rebuilds will solve the problem unless you fix those specific issues.
John
'69 911E
Old 05-19-2005, 02:56 AM
Longhoods Unite!
i rebuilt them right away when i got the car but i really didn't look for things being worn out. so basically its new stuff or have them sent out to be rebuilt again with new hardware.
Old 05-19-2005, 06:31 AM
scottb's Avatar
Have you tried www.tremotorsports.com? Dave and the guys are great.
1984 Targa
Old 05-19-2005, 06:37 AM
Longhoods Unite!
Bizzump! What all is included in the "pelican" rebuild kits for the Zenith 40 TIN carb? I didn't originally buy my kits from pelican (sorry) and i certainly didn't pay 68$ per side. Is the pelican kit more comprehensive?
Are the above listed sources the place to go for NEW main jets or other parts?
Thanks in advance!
Old 06-04-2005, 09:22 AM
rw7810's Avatar
You might just do a price comparison with Stoddards. When I bought kits, they were more like $49. The rebuild is the easy part. Sounds like you need someone to tune them on the engine by setting the mixtures, etc.
Robert Williams
70' 911T
Old 06-04-2005, 10:55 AM
excuse dumb question.. Does Zeniths have same style cross shaft linkage as Webers ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-04-2005, 11:20 AM
rw7810's Avatar
yes, I'm quite sure it is the same.
Robert Williams
70' 911T
Old 06-06-2005, 05:36 AM
Longhoods Unite!
anyone else rebuilt them, i'm gonna tear them down AGAIN and see if there is anything worn out inside, make sure the jets are flowing and etc.
so if there are any Zenith Carb Experts on the forum, please speak up. ANY and ALL advice is welcome and will be greatly appreciated.
Old 06-06-2005, 02:06 PM
if the throttle valve shafts are tight with the housing, the prob is your adjustment, maybe. The cross shaft gets adjusted at it's carb mounting to syncro them to each other. If it's not correct your symptoms sounds like the results.
do you have info on initial setup adjustments?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-06-2005, 05:13 PM
