Stud part # for mounting 74 915
Just spent some time on the phone with a pelican representative and we couldn't come up with the right part number. He's faxing me some pages so i can check, but i thought i'd check here as well
I've got a 74 915 that i'm mating to an 86 3.2L. There are 4 studs coming out of the engine that the transmission mounts on. Three are the same length, one is longer, since it also goes through the starter. These are the studs i need to track down because the ones i have are about 20-30mm too long. The length of the three that are the same length is about 128mm. The best matching part the pelican rep found was a 10x72.. That seems rather too short unless that 72 does not signify end-to-end length. thanks, |
| All times are GMT -8. The time now is 07:58 AM. |
