-   -   Euro H4 Install Question (http://forums.pelicanparts.com/porsche-911-technical-forum/174964-euro-h4-install-question.html)
Jubbie 07-29-2004 09:42 AM
Hey,
I just got my Euro H4's and am ready to install. Is there a 'right' and 'left' unit on these?
jazzbass 07-29-2004 10:03 AM
No. They're the same.
mb911 07-29-2004 10:48 AM
Yeah whats the deal with fittment on these things?? They surely don't clip on the top of the fender very well!!
Ben
djmcmath 07-29-2004 10:49 AM
No, they sure don't. I dropped one on the freeway the other day. Duct tape is your best friend.
mb911 07-29-2004 10:50 AM
Oh great Just what I want! I wish they just fit a little better. ANybody Know the solution??
RANDY P 07-29-2004 11:14 AM
I bent the upper tab outward with pliers a touch. Also, look at the back of the h4's and make sure the wire "supports" that are around the inside of the h 4 aren't in the way of the upper lip. When I bought mine they were in the way out of the box - had to rearrange 'em.
Make sure you have the special two piece screw. If some suppliers will tell you to use the USA 1 piece screw and that will work. Don't believe 'em, they came out of the factory with the two piece stainless screws.
Good luck
mb911 07-29-2004 11:17 AM
I 'll check it out
thanks
Ben
andyjboy 07-29-2004 12:50 PM
Never had any problems fitting Euro H4 headlamps to early 911's/912's I imported from the US.
All sets of Bosch H4's I've bought in the UK & Germany have had a single-piece chrome screw as the bottom retainer - I thought the 2-piece ones came with the paintable trim rings ?
Andy
jpnovak 07-29-2004 01:37 PM
the two peice screws are made for the paintable trim rings. A single screw will work if you have the primered finish or the chrome.
RickKlem 07-29-2004 01:45 PM
I ran into the same problem a month ago. Here is a link to my thread and what I did to fix the problem.
http://forums.pelicanparts.com/porsche-911-technical-forum/170739-im-having-problems-installing-h4s.html
Good luck
Rick
Wil Ferch 07-29-2004 01:48 PM
I also found these easier to install when the rubber "surround" that cushions against the body work is old and "somewhat" compressed...instead of brand-spanking new.
---Wil
Jubbie 07-29-2004 03:29 PM
Tanks Guys,
I'm off to buy some more duct tape.
