930 rotors....... brake experts
are 86-89 930 front rotors different from other 930 rotors?
Only the very early turbos, the first one or two years they came out (79?) were different. From then on, including widebodies, the front rotors are the same.
Yep,....
The 78-79 full-floating, flat-hat rotors will fit a narrow-body 911 and any 911 hubs. The 80-89 non-floating rotors use a cast-in hat and only fit a wide-body car.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
thanks I tried to snipe at the last few seconds and missed a new front set of 80-89 by $2.50 oh well they went for $203.50 and I bid $201.00
Can I ask further question on the subject?
The later rotors with the cast in hat only fit wide bodies. This means 'factory' wide bodies? The hubs on factory wide bodies are different than regular hubs? (trying to figure out all the different brake combinations out there) |
