North Coast Cab's Avatar
Wheel Bearing Race
Everyone refers to replaceing the race along with the bearings. I purchased the front inner and outer bearings and seals, but don't even see a race in the PP catalog. There is a spacer for $40, is that it?
John
1985.5 944 GTS
Old 07-29-2004, 06:46 PM
Who is John Galt?
Rondinone's Avatar
The race comes with the bearing. The bearing plus the race equals what you get in the box. Do yourself a favor and heat up the hub on a grill or in the oven before you try to pound it in, it will make the job much easier.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 07-29-2004, 06:48 PM
and put the race in the freezer, too.
Old 07-29-2004, 06:49 PM
Thanks fellas, I am now a confirmed idiot. I opened the boxes and there were the races.
John
1985.5 944 GTS
Old 07-29-2004, 06:53 PM
MBruns for President
JeremyD's Avatar
seperate the races from the bearings and stick in the freezer (don't mix them - mark each bag individually) Heat the hubs on the grill when you get ready to stick them in... Works like a charm...
Old 07-29-2004, 06:56 PM
84toy's Avatar
Be careful when you drive out the old races. I have seen people drive them out with a hammer and punch and if you booger the seat area, the new race will not seat properly.
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 07-29-2004, 08:16 PM
350HP930's Avatar
Only old bearings need to be matched up. Such effort is not required of new bearings.
Old 07-29-2004, 08:19 PM
You do not have permissi
john70t's Avatar
What timing. I'm still looking for stock ride height but found this excellent write-up by Thom:
http://66.34.72.138/howto/wb/index.html
Old 07-29-2004, 08:31 PM
It's best to not mix bearing races unless you know they are from the same manufacturing lot/run - then, maybe OK. If the bearing races are from different manufacturers, then suggest you don't mix.
'76 2.7-->3.2
Old 07-29-2004, 11:29 PM
