Guest
Posts: n/a
How to remove this dammn screw?!
I totally stripped the 6mm hex head bolt that goes into my passenger seat rail. It's recessed into the rail and I can't imagine a Dremel will fit down there. Is there some trick to removing a stripped hex bolt, when you can barely even reach it? Otherwise, a nice Brey-Krauss fire ext. mount will be for sale soon. Thanks.
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
If I were in the same situation, I would find an allen wrench/socket that's slightly bigger (either metric or standard), and pound it in with a hammer.
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Do you know the trick to getting to the bolts? Front left bolt acts as a seat stopper if I remenber correctly. I know if you pull one out, you should be able to get to the rest no problem. As far as the stripped hex. Hammer a flat tip screwdriver into it.
Troy 72' 911 T 97' Boxster 81' SC coupe / sold 76' slant nose 81' SC Targa / sold 77' s / sold 67' 912 / sold 89' 944 / sold 74' 914 / sold 71' 914 / sold |
If you cannot get it out otherwise, you could probably use a large drill bit (almost as big as the bolt head) to remove the top of the bolt. Then remove the seat and use vice grips.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Guest
Posts: n/a
I'm gonna try to find a 7mm hex wrench and pound it in there. For some reason, both my hex sets do not include a 7mm wrench. There is not any room there to fit a drill bit. I have less than 6" clearance above the hex head. It's very hot out today too. This is a lot of fun.
Schleprock
Put a narrow chisel in the seat rail and slice the head off the bolt
Kevin L '86 Carrera "Larry" |
Sounds like you have less clearance than i do. There is a big difference between a 6 and 7 mm. Without seeing how badly your bolt is stripped, If I were buying one for this purpose, I would consider a 1/4 inch (@6.35mm). Good luck!
Guest
Posts: n/a
Ok, just found out that raising the seat with the button gives enough clearance to just about anything now. So I'm gonna cut a groove in the head with a Dremel and then find the widest flat tip screwdriver and back it out. I'm off.....
Guest
Posts: n/a
This sucks! Dremel will barely fit and even with the groove I cut, I cannot get my impact screwdriver to do anything with it. I'm really at a loss now.
take a (narrow) chisel, and position it on the right side of the at an angle and dig into the bolt head a little and try to tap the bolt loose.
Chris |
Schleprock
That's two votes for chisel..................
Time to get "caveman" on that stupid bolt.
Guest
Posts: n/a
SUCCESSSSS!!!!!!!!
I beat the lving pis$ out of it with a chisel and then drove a brand new torx socket bit into it. Then I used a socket to twist it out. Now I can go to the hardware store and match the good bolts. Thanks! |
Schleprock
You'll find that those bolts are "low head" cheese head/allen bolts. The heads are shallower to let the seat rail slide over them without interference. I'm pretty sure you can replace them with standard hex head bolts, but you might need a thin wall socket to be able to tighten them. Most deep sockets are thin wall, but might be too long.
The low head metrics might be hard to come by at the local hardware store. Hopefully you have a good metric store nearby. If not, eagleday.com has those shallow allen bolts. So does mcmaster.com and metricmcc.com M8x20 is the recommended size. A little longer is no big deal. Just put a tiny bit of antiseize on them (especially if there's exposed threads with longer screws) to make them easier to remove next time.
Actually..they're available from the Porsche dealer pretty cheap....
--Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Schleprock
1/4in drive socket fits the hex.. 3/8in drive is NG in my car.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
