Broken tach.. 67S
As soon as the ignition is switched on the tach needle just pegs on the other side. Any thoughts on what to check? Thanks, Bill
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 04-20-2004, 02:22 PM
How about a bump after 3 months...
Any ideas??
Past:
Old 07-30-2004, 08:35 AM
Early_S_Man's Avatar
Porsche Crest
The problem is inside the tach circuitry ... most likely a shorted transistor!
Analog tachs use a calibrated one-shot multivibrator to drive the meter, discrete circuitry back in '67 ... and about the only thing that could make the needle peg when power is applied ... is a short accross the output of that monostable, most likely the 2nd transistor itself.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-30-2004, 09:19 AM
If you took it apart and reverse engineered a schematic I'm sure all the EEs on the list would stumble over each other giving you trouble shooting steps.
Old 07-30-2004, 11:22 AM
Thanks Warren, that gives me a place to start. I'll post more if/when I get it apart. Bill
Past:
Old 07-30-2004, 02:09 PM
Shaun @ Tru6's Avatar
I've got a good one if yours is unfixable.
Tru6 Restoration & Design
Old 07-30-2004, 03:28 PM
Well, here's the inside of it. Doesn't do me much good though..
The connections left>right say 12V, 1, and -. Guessing the '1' is a lead from the ignition?? Anyway, I've got a volt meter and could hook this thing up to juice, but there's so many little diaode's and the like I'm not real sure if this is doable.
Shaun, is your tach a S tach with the 7200 redline, if so how PM me what you'd like for it. Bill
Past:
Old 07-30-2004, 03:46 PM
Oops, here's the pic.
Past:
Old 07-30-2004, 04:59 PM
Porsche Crest
That pic won't help any! The carb. is in focus, but not the tach!
To be useful, the camera needs macro-focusing capability. Both sides of the printed circuit board are needed, in precise focus, and closely cropped, i.e., nothing else but the board! The numbers on top of the transistors should be in good, even light, and in focus.
Warren Hall, Jr.
Old 07-31-2004, 08:59 AM
Yea, I guessed that pic wouldn't do much good. I'll play around with the camera (Canon a40) some more and see what I can do, not sure if it has macro mode or is just a limitation of the lens.
As another fix, Shaun has given me a fair price on his, but it's a 7000RMP. Are the internals the same, and could I mount my 7200 face on it?
Past:
Old 07-31-2004, 09:29 AM
Warren, Here's some better pics. Let me know what else might be helpful. Thanks, Bill
Past:
Old 08-01-2004, 01:50 PM
Bill,
Those are much better!
I haven't seen such ancient transistor cases like that in use commercially since about 1965! Looks like three Valvo transistors ... 2 ea BC710, and an AC128.
Actually, if you get the other tach ... I would recommend just swapping the board, and don't mess with your meter face or pointer. The 'guts' should be interchangeable!
Warren Hall, Jr.
Old 08-01-2004, 05:06 PM
Yeah, I was wondering that if I did somehow find which one was bad, how I'd find a replacement. I think I'll do just that and swap boards with a good one.
Oh well, at least I figured out how to use macro mode on my camera.
Past:
Old 08-01-2004, 07:36 PM
