teardrop's Avatar
Emissions results on 3.2
Hi all,
I am in the UK and I just had my car pass its MOT. (Yearly test for safety and emissions).
All was well but one thing intrigued me.
My car had CO of 1.5% and HC of 74ppm. This is well within the MOT specs so no problem from a legal point of view (UK limits are 3.5% and 1200ppm) but the testing guy pointed out that his chart showed a 3.2 as having an ideal of CO 1.25% +- .25 and HC of 800ppm.
Now, I'm not worried (should I be?) but what should the 3.2 emisions be. Maybe his chart is plain wrong?
I had a figure of 77ppm last year from a different shop so I thing his tester is probably accurate.
Can a low figure for HC be a bad thing? I thought this was essentially a measure of how much fuel is being burnt and therefore the lower the better.
This is for a UK 3.2 without a CAT so any US measurments would presumably have to be upstream of the CAT.
Cheers
Andy
Old 08-02-2004, 09:02 AM
teardrop's Avatar
One more try...
Old 08-03-2004, 01:58 AM
Fuchs w h o r e
Those numbers are excellent for an engine without a CAT.
The CO is a measure of how you (or the ECM) have adjusted the mixture. The HC is a measure of what your engine does with that mixture. A low HC means your engine is burning the mixture very efficiently. Any engine pushing less than 100ppm of HC without a CAT is doing very well. I can say without doing a leakdown test your valves are sealing extremely well. A lot of people don't realise how valuable an emissions test is as an engine diagnostic.
Old 08-03-2004, 02:42 PM
