Show me your cage!
I want to see how you built your cage and where the mounting points are.
When the 935 accelerates , the world is a far smaller place. 935/78 Moby Dick The project 911 page: http://project911.luminasweden.com/ |
![]() StableEnergies bar. Cage was test fitted, plates located, and then welded in place. Bar then bolts onto these plates. The fit is very, very tight. I would only recommend this one for cars that will have most of the interior removed. |
Tru6 Restoration & Design |
Nice,nice show me more!
Why I asked after pictures? I have 57 kilo (around 110 lbs) steel tubing here and smoe are prebent from a well known shop, but I´m a little novice about fitting a cage in a 911. Thanks a lot!
