jdowty3's Avatar
AC compressor power
I'm looking for info about where to track down a problem with not getting 12V to the AC compressor. With the temp control at max and the evaporator fan on, I'm not getting enough voltage at the compressor connector to engage the clutch. I can see a small light spark when I touch the connectors so I know it's seeing a little power. I know there is a relay by the evaporator and some kind of temp switch in the passenger footwell. Can anyone suggest where to start diagnosing?
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-05-2004, 10:32 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Mine failed at the ac switch in the center console. It got hot as H and then died. If not there, there is a relay in the smugglers box on the side wall and if not there, the ac resistor for temp control in the center console may have failed (you can jumper that out very easy).
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 08-05-2004, 11:09 AM
scottb's Avatar
Have you put a voltmeter on the connection to the compressor? That's where I'd start.
If you have to replace your switch, Griffiths sells a pretty slick looking replacement for the stock switch.
1984 Targa
Old 08-05-2004, 05:19 PM
