-   -   Weber Settings for 2.4E (http://forums.pelicanparts.com/porsche-911-technical-forum/176227-weber-settings-2-4e.html)
6771911esses 08-05-2004 06:18 PM
Just got this motor built. Has Webers right off a 2L 911s. What jets/chokes/venturis should I use as a baseline for a 2.4E with 2.2E pistons? Comp. ratio is probbably around 9.1-9.2:1
Mike
jluetjen 08-06-2004 04:39 AM
I've distilled down people's carb jetting experience with 2.4's that I've collected from this BBS and other places. It will give you some ideas of what seems to work and what doesn't.
http://forums.pelicanparts.com/uploa...1091792208.jpg
I'd also fax and then call Richard at PMO Carbs. He can answer questions like this off of the top of his head and has all of the parts that you'd need. I believe that you can also get most if not all of the parts that you need through Pelican too.
