Senior Member
ohecht's Avatar
TO bearing spring washer orientation
Is the picture on page 301-14 of the Bentley manual backwards?
Whe I install the spring washer that way on my 82, the TO bearing is loose in the pressure plate.
Reversing the spring washer makes the bearing a tight fit, which I assume is better.
That is how I did my last one, but it only lasted a few thousand miles and I want to make sure that was not the problem (I think the flywheel was machined incorrectly).
If someone could just confirm the spring washer orientation, I would appreciate it.
Thanks in advance,
Olivier
Olivier Hecht
1982 911SC
Old 08-07-2004, 09:18 AM
