Sweetest 3.2 on the planet?
Well at least a candidate. Check this out: http://brentwoodrocketscience.com/r2/r2.htm
Going into an RS replica...
Warren & Ron, may you rest in Peace.
Old 08-06-2004, 01:38 PM
Randy Webb's Avatar
The CF shroud and black color theme is sweet.
But, preformance-wise it is not that exceptional - most of the things done are common for a hot rod engine of this type. AND, they didn't twin plug it. Also, they ceramic coated the headers, but not the pistons(?). The best thing would have been to ceramic line the exhaust ports, not the headers.
Overall, I think it's good documentation, and a nice color theme. But not an ultimate hot rod.
Old 08-06-2004, 01:50 PM
I noticed that as well. He needs to check out Aaron's "Twin Plug Goodness...Look what I made" thread.
Old 08-06-2004, 01:58 PM
Gon fix it with me hammer
svandamme's Avatar
it doesn't have MFI
if it did, i would agree
ok , and S-kinda cam's , but can't tell from the picture
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-06-2004, 01:59 PM
Other "best of the 3.2 engine" pics are welcome........Bring the MFI on....
Old 08-06-2004, 02:01 PM
bigrubberjeep's Avatar
It's a sweet motor, but I got to agree, the twin-plug would have been worth the wait.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 08-06-2004, 02:06 PM
Another candidate:
Although our own talented fabricator, Natchamp, started with a 3.0 he uses 3.2 P & Cs in his TT .....
Old 08-06-2004, 02:08 PM
svandamme's Avatar
don't have one
but if i would .... i'de sure as hell would want MFI on it
maybe not the newest thing , or the most performant thing
but i don't like chips and electronics on a car...
Stijn Vandamme
Old 08-06-2004, 02:09 PM
Twin Turbo Goodness:
KobaltBlau's Avatar
I prefer this 3.2 based creation:
Supertec built 3.5 MFI
Andy
Old 08-06-2004, 02:19 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Ah yes, henry's engine is a masterpiece, I would love to have that engine in anything.
74 911s neverending story. two feet and a jetta for now.
Old 08-06-2004, 02:24 PM
Randy Webb's Avatar
I think HS's engine wins the 3.2 (incl 3.2+) contest for what I've seen in NA engines. We'd have to put turbos in a differe category.
BTW, how many folks have used either CS valves or the 993 valves in theirs?
Old 08-06-2004, 02:33 PM
I agree! From what I have seen and read (not very much) HS kind of put Andial's 3.2 engine conversions and rebuilds out of business. They seem to stick to 3.6 and up now.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 08-06-2004, 02:36 PM
upppp, uppp, uppp....my thread.....Turbos allowed
Old 08-06-2004, 02:37 PM
david914's Avatar
Man, these engines are works of art. Maybe this ought to be the "ultimate engine porn" thread!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-06-2004, 02:40 PM
svandamme's Avatar
MFI ... yeah ... drool
ideally , i'de like to see this engine
without the fancy colours... with a twin plug
Stijn Vandamme
Old 08-06-2004, 03:31 PM
rdane's Avatar
I'm rather fond of this one.
Old 08-06-2004, 06:17 PM
Jeff Alton's Avatar
Why would they twin plug it? With 9.8:1 and carbs and that cam does it really need it?
www.turn3autosport.com
Old 08-06-2004, 07:30 PM
rdane's Avatar
Most of the professionals here have stated that anything over 98mm pistons need twin plugs to avoid detonation without race gas. This 3.5 engine was built to run 100 octane unleaded race gas.
Trick Leaded 115 octane is $5.66 a gallon here. Trick Unleaded 101 octane is $5.25 a gallon.
The Carrera 3.2 engine shown was built with high dome RSR pistons. They are better served with twin plugs because of the poor combustion chamber design with the RSR piston. Take a look at the web page photos. Again it is a detonation issue even with a 3.2 and 9.8:1 compression. Bad gas or a hot day and you'll have problems.
the builder's comments:
Originally, the plan was to twin-plug the heads and run dual spark plugs, but the cost of the ignition componentry and availability of information curtailed that plan rather quickly. Also, 9.8:1 compression should still be safe for pump gas.
Make up your own mind on that one. The info is well know and easily found. I'd want twin plugs on this 3.2, the 46s add to that decision, like most here have requested.
The 3.5 specs from Henry
"Also when built properly, the 100 mm engine will also offer tremendous results. We just built a 3.5 MFI single plug engine that amazed us on the Dyno. 369 RWHP @ 7660 rpm.
the specs:
3.2 case, Carrera II oil pump
Mahle 100 mm Ps & Cs 10.8 to 1
3.3 turbo crank with 962 journals / 3.0 rods, titanium 935 rod bolts.
3.3 turbo heads ported & flowed by Supertec 41 mm in 38 mm ex. Aasco springs, ty retainers
1 and 7/8 header
Elgin cams 320 / 304 set @ 6.2
Recurved Dist by Supertec 36 degrees total advance 100 octane unleaded
Taylor wires, MSD ign box 7800 rev limit
Custom MFI 41 butterflies, stacks, custom MFI pump, Fuel lines and enrichment by Supertec
wheel dyno was a Dyno Jet @ Pecora Dyno Service, Costa Mesa
369 @ 7660
326@ 5300
Old 08-06-2004, 07:51 PM
Elombard's Avatar
FYI the brent wood rocket science guy is here on Pelican and in Atlanta. I have seen the car - very very nice. Seems to run exceptionally well. I cant remember his screen name - something japanese sounding. Hatori maybe?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-06-2004, 08:20 PM
