-   -   Torques in Tech. Spec. Book (http://forums.pelicanparts.com/porsche-911-technical-forum/176637-torques-tech-spec-book.html)
Randy Webb 08-08-2004 06:06 PM
Generally torque values are designed for lubricated threads (a bit of motor oil), but someone told me that Porsche spec'd the torques in the Tech. Spec. Book for dry threads -- and that if the threads are oily (like most old ones), then they need to be adjusted.
Does anyone know if this is true? If so, let me know where you found it out (Porsche manual, TSB, told that by service mgr., or F. Piech appeared to you in a dream, etc.).
Zeke 08-08-2004 06:45 PM
All this talk about torque.....oil, no oil.....wouldn't the thread pitch have somethig to do with it if friction is such a big factor? Generic torque charts that I have seen and downloaded don't say for pitch, just dia.
And the Porsche charts already know what bolt they are referring to, so pitch is accounted for. (They ususally describe it by location rather than by size.)
Lastly, dont' most fasteners come with and are stored with a light oil while waiting to be used on the assembly line?
AFJuvat 08-08-2004 06:56 PM
Torque values are generally assumed as dry unless specifically mentioned in teh workshop manuals.
AFJuvat
Randy Webb 08-08-2004 07:06 PM
A lot of the stuff from PAG is dry when I open it. Not sure about the pitch - usually the surface cond. (plated vs. black oxide) is cited as the major effect. It may be that only extreme pitches (thus rarely seen) really affect the torque. I know the bost science web site gives threads about a 45% contributin and the washer friction about the same....
AFJ - maybe I should get a workshop manual and search thru it instead of the Tech. Spec. Booklets...(?)
