Nothing like a 911
FrankieG's Avatar
Ran out of gas! Now what?
Well, now I know how you find out your gas gauge is broken! Actually, I was glad when we figured out it ran out of gas, it was a quick fix and I was back on my way. The car has run fine since. My question is..can this do any damage to the engine? Is there anything I should do? Just drive it?
1982 911SC Targa
2009 Cayenne
If it doesn't kill you...it makes you stronger
Old 08-03-2004, 05:37 PM
Drive it, it's fine... Million dollar 917's run out of gas and there fine..
Old 08-03-2004, 05:43 PM
Nothing like a 911
FrankieG's Avatar
Thanks..I figured that. just someone told me that there could be rust or debris at the bottom of the tank (it's original 1982), and that could be sent into the engine.
1982 911SC Targa
2009 Cayenne
Old 08-03-2004, 05:46 PM
More likely that stuff would clog something like a fuel line, but there is a fuel filter for that reason. You never really get everything sucked out by the pump anyway.
Old 08-03-2004, 05:51 PM
Nothing like a 911
FrankieG's Avatar
Thanks!
1982 911SC Targa
2009 Cayenne
Old 08-03-2004, 05:54 PM
Randy Webb's Avatar
How long has it been since you changed the fuel filter? They are maint. items. Follow the schedule or do it early if paranoid.
Is your guage broken? Can't tell from our post.
Old 08-03-2004, 06:26 PM
vash's Avatar
i also thought that running out of fuel is harmful to the fuel pump. i think the gas also acts as the coolant for the pump. maybe keep a close eye on it from now on.
poof! gone
Old 08-03-2004, 06:28 PM
david914's Avatar
Ditto on the fuel pump. I ran out of gas right after I bought my SC years ago, and within the week, the fuel pump died. Of course, your mileage may vary... Just keep and eye (and ear) out on it for a while. Just a precaution.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-03-2004, 08:31 PM
The gas acts as coolant and lubricant for the fuel pump. So, when you run out of gas you are domaging the components inside the pump.
It can be deadful for the pump under such circonstances.
Hope everything is well.
Good luck, Phil.
Old 08-05-2004, 09:13 PM
Nothing like a 911
FrankieG's Avatar
Really. Just got the car back rom it's regular service yesterday, my mechanic did not mntion any problem with the fuel pump, although maybe he didn't check it. Dumb question - is a fuel pump replacement expensive?
1982 911SC Targa
2009 Cayenne
Old 08-10-2004, 09:41 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
The replacement can be done fairly easily. You will need a well ventilated area and you can drain the fuel from the lines. If the pump is working right now, you might not have any problems. Don't let the gas go below 1/4 tank.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-10-2004, 09:45 AM
Nothing like a 911
FrankieG's Avatar
Since my gauge is so unreliable, I am keeping a close eye on the fuel at all times. I really should troubleshoot the fuel gauge, but the problem from what I hear can be one of many, from wiring, to the tank sensor, to the gauge...
1982 911SC Targa
2009 Cayenne
Old 08-10-2004, 09:53 AM
if you hear a noticable increase in the sound from the pump might as well order a new one in advance.. I'd at least do a fuel pressure and volume check.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-10-2004, 10:15 AM
