Why are the rpm so much lower in the recent test than last year? Did you put off-road tires on it?
I PASSED!
My wrench just called... and a new CAT was the solution. I will post the numbers (and $$$ damage) in a few hours once I get the car! Wow. What good news! :D :D :D |
Congratulations. Now sell that car to me for 7K less than what you paid for it a year ago. Depreciation, you know....... (heh, heh, heh)
Ok, the numbers (fail test / pass test):
15 MPH - 1959 RPM / 2130 RPM CO2 - 13.88 / 12.20 O2 - .46 / 3.6 HC - 47 / 1 CO - .82 / 0 NO - 292 / 112 25 MPH - 1939 RPM / 1993 RPM CO2 - 13.90 / 12.10 O2 - .41 / 3.5 HC - 36 / 6 CO - .81 / 0 NO - 259 / 110 Obviously, the numbers dropped big time with a new CAT. This whole getting-my-car-smogged mess cost me about $415 and five months of headache! |
Emission, by new cat, do you mean one that you borrowed?
In reading this thread, I think I need another cat. I failed SMOG on my 3.2 with S. Wong chip. It's an ROW car.
I got 15 mph @ 1,237 NOx and 25 mph @ 873 NOx, I noticed the state has lowered the standards, (allowable max's are 804 and 685 respectively). I also got HC at 15 mph @ 73, and 25 mph @ 23 (allowable max's are 97 and 79, respectively). On CO I got 0.19 @15 mph, and 0.15 @ 25 mph (allowable max's are 0.59 and 0.45, respectively). Engine and cat were warm, and it has an O2 sensor at the inlet to the cat. I have another cat that has been sitting for years, but I noticed that I didn't seal the ends. Any thoughts. Should I remove the S. Wong chip and put the original one back in for good measure? Change oil, adjust valves, change air and fuel filters? Any thoughts would be appreciated. |
You can put 50 lbs. of air in your rear tires to help low speed drag.
Is that it? Just the cat? I have an older one in my garage. What about swapping the Steve Wong chip for the original? Any other suggestions?
Hugh,
I was in the same boat as you with my '77 3.2 with a Steve Wong chip. My NO was @ 1297!! My CO was 2 below the limit. I traded my euro premuff for a good used cat, installed a borrowed stock chip and ran a tank full of techron (10oz-10gallons fuel) and retested. I passed and my NO came down to 600+ and CO .10 points lower. I tried unplugging one of the fuel injectors but when I did it ran alot rougher. The one cylinder would basically become an air pump and you should see a 16% improvment in smog levels. As I said I didn't try this but was willing to if I failed the second test. YMMV Good Luck |
- Mike |
Put in stock chip and a less used cat and this morning she passed, blew a 289@15 mph and a 385@25 mph on the NOx. CO and HC came down as well by about 50%.
What I found that is odd, is that my NOx limit allowed by the State in 2003 when I bought it was 1106 ppm, then in 2010 (today) its been lowered by the State to 804 ppm. So it appears that the State is doing something fishy. I thought whatever the standard for your model year remained the same number. |
| All times are GMT -8. The time now is 10:51 PM. |
