Greetings
Hey, I'm new here. Just bought an'82 911SC. Nice car, I'm looking forward to having a Porsche again (I owned an '87 911 years ago when I lived in Europe. Now THAT was fun on the autobahn!). The car does suffer from hard starting after warm. It came with a new fuel pump the prior owner didn't install, so I guess that is my first job. Hopefully that clears the problem, otherwise I'll move to the accumulator. I've searched the forum for the location of said pump, I think it is under the front of the car car. Any more precise info on this install? Thanks!
Canucks Fan
There is probably something in the search although i have never have any luck using the search. Our host has a book 101 Projects and its covered in there, real handy book to have around. I'm sure someone will jump in and give you some advice, don't forget the fuel filter. welcome to the board, you have any pic's of your car?
Yes, the fuel pump is located just above the steering rack. There is a belly pan that has to be removed to get to the pump.
It won't hurt anything to install a new one but it may not solve the problem. warm start problem SC Warm start problem, after at least 90 minutes sitting These threads will get you started. Welcome to Pelican, BTW. As posted by sm57, I would suggest getting "101 Projects" as well as a Bentley manual as these will prove invaluable to DIY'ing your SC. Good luck with it and please post your results.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Pics???
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Welcome....looking forward to the pics, too.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
