Power window problem
I started to raise the passenger window last week, and the switch on the door broke. ( passenger side switch). Than I couldnt raise or lower either window.
No problem, I ordered a new switch, hooked it up, still neither window works. I checked the 25 amp fuse, it was blown. Tried 3 times to put a new fuse in, as soon as I turned on the ignition, it blows. Any ideas? Is there a separate power window relay that might be bad? I traced the black wire in the fuse block for the power windows, and it goes to a round relay. A another red wire gows to this relay, and it is for the blower motor , which works fine. Thanks! |
Re: Power window problem
------ yep. The sw solid red is somehow contacting the brown ground.. if your lucky? "power window relay that might be bad?" ------- I doubt it 'cause this all started when you changed sw's. The black wire goes to the window relay. Then there should be a red/white & red/black connected to this relay. There may be 2 red/white wires comming together at the relay instead of one red/white. why not list your model year and any mods in the "signature" to aid future reference. |
So with the broken passenger switch, it affected the operation of the drivers side? I will check my wiring!
Thanks Ronin! |
All 3 sw's use one fuse. |
I checked and corrected my wiring, put a new fuse in, and they work fine! Thanks!!!
| All times are GMT -8. The time now is 07:00 PM. |
