Lug nur removal ? - Don't laugh pls
I have a lug nut that appears to be a security type , ie. you need a key to remove it. It is a 78 SC. of course, I don't have a key and can't locate one.
What is the best approach to removing it dremel cut-off & replace the lug? I tried vice grips, but could not get a good grip. I am afraid to use heat, the soft nuts may melt? TIA, Earl |
Broke
Earl...a month or so ago there was a thread about just such a problem. Search under 'lug nuts' and I'll bet you'll get your answer
Beer is proof that God loves us and wants us to be happy. B. Franklin 93 968 Cab 81 SC Targa (Princess) Now Residing in Denmark 1973 RS Z28 Vash will never own it! |
easy on your soft nuts.
The lock system on mine needed to be broken off using a small chisel to break out the lock cylinder. then the sleeve should slide off
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I would weld...or tack weld a nut onto the lugnut, then use the appropriate sized socket with a breaker bar to take it off.
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
If yours is like mine, it's not a keyed lock, just an oddly shaped nut that requires an "adapter" between it and a conventional 19 mm socket. If that's the case, try a better, larger pair of vise-grips, or channel locks. If they still fail, I'd try a small pipe wrench. You'll end up ruining the nut, but who cares?
BTW, the "adapters" are probably still available from Porsche, if you went to a dealer, they could get you the right one. Jerry '78 SC |
Jerry,
You are correct. I need an adapter ( not a key, mistake in describing as such). Right also, I don't care about the nut, just want it off. I will try a larger vise grips. Thanks Earl PS I can imagine what Porsche dealer would want for that? |
how do you "tack weld" to an aluminum nut?
Not easy for the home amateur.... ![]() --Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Unregistered
I've had luck in the past with this method:
Find a 16 pt. socket that almost fits over the locking nut but not quite. Hammer it over the nut so that it bites down on the OD, then use a ratchet or breaker bar to unscrew it. It will trash the locking device but if you don't have a key, who cares? It may also damage the socket a little, so don't use your best snap-on set. All in all it should take a couple minutes. |
Banned
Ditto What Sammy Says
Kind of a different subject but You tack weld on aluminum with a Tig torch!
Ben |
Senior Member
Is the car stolen?
Seriously, check the glove compartment and empty out the tool kit to find the key. It is probably in the car somewhere. John
'78 Targa in Minerva Blue |
Unregistered
If you go anywhere near the wheel with an arc welder, please pay very close attention to where the grounding clamp is. That goes for all welding around machinery.
Arcing through a bearing is way down near the bottom on the good/bad scale. |
just hop on a tool truck, or go to sears, and get the proper size stripped nut remover tool. looks like a socket with internal helical teeth. tap it on, turn it off. all the upscale wheel stealers have a few handy.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-10-2004 at 04:38 PM.. |
I'm w\JW. Those nifty tools you see on infomercials are great for this type of problem. Sears can hook you up. Every mechanic should have one.
72 911 Although it is done at the moment, it will never be finished. |
Oh yeah...forgot about that. Heck, I even have the kit and I still forgot. Here's the link from the Craftsman website.
THANK YOU ALL
YOU GUYS ARE GREAT.
esp,. JW- JUST GOT BACK FROM SEARS, LUG NUT IS OFF!!!!! JOHN WALKER, YOU HAVE HELP ME MORE TIMES THAN I CAN COUNT. JUST A FEW WEEKS AGO, I WAS SINGING YOUR PRAISES WHEN I FOLLOWED YOUR ADVICE ON REMOVING MY HEAT EXCHANGERS. HEAT IS OUR FRIEND- ALL NUTS OFF & NO BROKEN STUDS!!! YOU ARE A TREMDOUS RESOURCE. I APPRECIATE YOU TAKING THE TIME AND SHARING YOUR EXPERIENCE WITH PEOPLE LIKE ME - WRENCH IMPAIRED. AND NO THE CAR IS NOT STOLEN, IT IS MY FIRST PROJECT. SO IT IS MISSING A FEW THINGS, LIKE - ENGINE, FUEL LINES AND NOW A LUG NUT. THANKS AGAIN UNTIL THE NEXT POST - BE SAFE EARL |
ALuminum to steel if you want to solder Oh yeah I teach metal science and welding So I had to be a smart a@#.
Ben |
