-   -   "High output alternator" from Australia (http://forums.pelicanparts.com/porsche-911-technical-forum/177071-high-output-alternator-australia.html)
Randy Webb 08-14-2004 07:34 PM
If you put a scope on it, I think you will see some ripple -- so it would be "pass-thru" ripple. Or am I wrong about how these things are connected?
But I take your point. So, do you know the difference between the older regs. and the newer ones? Are the older ones electro-mechanical, with the newer ones having electronic devices in them?
Lorenfb 08-15-2004 10:01 AM
"Are the older ones electro-mechanical, with the newer ones having electronic devices in them?"
You got it!
Alternator regulators are NOT "series pass" regulators as are regulators for electronic devices.
As I said, they just "turn-on/off" the alternator at preset voltages.
Just look at a Porsche wiring diagram and you'll see how they're connected
which will indicate how they function.
