-   -   Power window to manual conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/177072-power-window-manual-conversion.html)
Argeo 08-11-2004 07:41 AM
Is it dificult to switch from power to manual on a 77 911? Is there any welding or drilling involved or is it basically remover the guts and put the other set of guts in. I know I will have to fix by panels also.
Thanks,
Argeo 08-11-2004 10:16 AM
Anyone?
Hetmann 08-11-2004 10:23 AM
I just did a repaint on my 78. I have manual windows in my car. I took the doors apart and got to see how things work in there. Putting them back in was not that hard and there are a few things to line up and adjust before you cinch things down. My regulators were working ok so I didn't rebuild or replace anything although I know there are parts that can be replaced to improve operation. I would think this would be a simple retrofit as I am sure all the doors out there have the correct holes for the manual regulators. There are different kinds available so I would recommend that you find the better (I think later) mechanism if you can.
enolam 08-11-2004 02:31 PM
I replaced the electric motors and requlators in my 77 with no problem. Just remove and replace.
