-   -   CA SMOG test failure and unexpected results...HELP :( (http://forums.pelicanparts.com/porsche-911-technical-forum/177094-ca-smog-test-failure-unexpected-results-help.html)
stlrj 08-13-2004 08:38 PM
Running so rich, I would be surprised if the cat wasn't totally burned out by now.
Joe
johnsjmc 08-14-2004 08:43 AM
The cat is still working fine. Notice the HC and NOx are still well within limits even though the CO was high. The front section of a 3 way cat works by stripping the oxygen from the NOx and then adds it to the HC and CO in the rear section to produce more CO2 and some H2O. A normal reading from either of the 2 gases from one section and normal NOx from the other shows a Cat working as expected .If it has failed you usually see all 3 gases as high.If the matrix has become clogged (from a partial meltdown)you would not have seen the pass after restoring the mixtures with a new O2 sensor either.
stlrj 08-14-2004 09:51 AM
Good point!
Joe
