Unregistered
sammyg2's Avatar
1 7/8" crows foot work for 46mm?
Does anyone know if an 1 7/8" crow's foot wrench will work OK on the 46mm cam nuts? I know it's close, just wondering if anyone's BTDT.
Tanks
Old 08-14-2004, 12:56 PM
sayah's Avatar
See my reply on the engine rebuilding site.
sayah
Old 08-14-2004, 01:45 PM
1 7/8 is almost 48 mm. I don't think I'd go that route.
Old 08-14-2004, 01:47 PM
I think it the same as 1 13/16s> I would have to look. Or maybe do the math . Any how I bought a wrench for 10 bucks and cut the box end off and drilled a hole and filed it down to except a 3/8 drive. Now I know everybody is thinking cheep but I was in a pinch. It worked so well I have used it on 2 engines since with no rounding of the cam nuts
Ben
Old 08-14-2004, 06:36 PM
Ove Ove is offline
911 driver
Ove's Avatar
Talking
The crow's foot wrench is not an ideal tool!
The problem is that you apply force off the center of the nut.
This makes it easy for it to slip. I was VERY careful when I tried to remove the cam nuts on my engine with the 46 mm crow's foot, but it didn't work.
I bought a 46 mm socket and welded it to a long piece of pipe.
http://forums.pelicanparts.com/uploads2/IM000377a1080999519.jpg
I seriously consider making another tool which allows me to torque the nuts to the correct specs without the use of a crow's foot.
Ove
'77 911S targa
Old 08-14-2004, 07:43 PM
Unregistered
sammyg2's Avatar
Just exactly how tight are these nuts going to be?
Old 08-14-2004, 08:01 PM
Randy Webb's Avatar
Tighter than duck's cloaca.
Old 08-14-2004, 08:05 PM
Ove Ove is offline
911 driver
Ove's Avatar
If you're lucky you can get them off with the crow's foot tool. In most cases it will work.
In my case... Well, let me just say I'm glad the steel pipe was no shorter than 4 feet
Ove
'77 911S targa
Old 08-14-2004, 08:14 PM
Zeke's Avatar
The factory tool looks similar in that the cam holder goes thru the the 46mm socket. But, It's a BIG T wrench with a cutout on the shaft for the holder tool.
Someone should do this right. Get some 46mm 6 pt. Sockets and drill them out for the cam holder tool and weld a bar on the side of the socket.
Ben?
Old 08-14-2004, 08:26 PM
Milt,
Shoot I can't even get my mufflers done but maybe I could take these on as well.
Ben
77 911 3.0
75 914-6 (2.7) Think its sold???
Old 08-15-2004, 08:06 PM
Now in 993 land ...
aigel's Avatar
150Nm / 110 ft/lb on the nut. Nothing you want to do with a tool that does not fit properly. The factory tool works just fine, unless you are crosseyed or epileptic. Just kidding ...
George
81 SC (sold)
Old 08-15-2004, 10:27 PM
