NSX NSX is offline
NSX's Avatar
Unhappy Running rough
I have a 911 SC that quit running while in traffic. i had a new permatune system installed and a new coil. the car ran again but very bad. i was told it might be the distributor so i had it replaced but its still the same does anyone have any ideas? it starts up perfectly and idles great but as soon as you come off idle or there is a load put on the car it sounds like the ignition is breaking down please help!
92 NSX
Old 08-12-2004, 12:18 PM
unrelated to your issue.... sorry, I can't help there.
I am thinking about moving to SC. Do you like Hilton Head? any porsche crowd?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 08-12-2004, 01:11 PM
NSX NSX is offline
NSX's Avatar
Hilton head rocks! i love it here been here 22 years and loving it! tons of porsche here and robeling road is an hour away for those porsche track days!
92 NSX
Old 08-12-2004, 01:14 PM
What is your feeling about the Northern part of SC.... the Myrtle Beach area? too touristy?
What about the economic base? I am a financial advisor at Merrill Lynch and would be looking for clients in the area as well..........
Old 08-12-2004, 01:17 PM
Designer King
Paulporsche's Avatar
If you do a search for things like the DME and relay. O2 sensor, warmup regulator (WUR), control pressure, mixture adjustment, plug wires, grounds, timing, and rotor and cap, you will find some of the common causes of and solutions for rough running.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-12-2004, 02:27 PM
