-   -   Valve ticking, but not a valve? (http://forums.pelicanparts.com/porsche-911-technical-forum/177222-valve-ticking-but-not-valve.html)
jmcjunkin 08-12-2004 08:26 PM
Blackbird 225 - I have checked my valve guides and they looks great, so it is either the feet or the problem you have. It drives me absolutely nuts. Does the cam lobe / rocker problem noise happen when cold too or just when warm?
blackbird225 08-13-2004 06:07 AM
Only when hot... Sounds quite nice when cold. I was told that worn valve guides equal more eradic ticking ( every other time, etc) and oil consumption. Mine ticks loud eveytime that cam taps that rocker. I'm nearly certain of it. I don't have oil consumption problems.
HTH
Michael
hkspwrsche 08-13-2004 07:28 AM
I had the same problem as black bird in my SC 3.0. The exhaust side (lower) bank 1,2 cyl area. I replaced the rockers, shafts, seals, elephant feet adj. for all 3 lower. The whole deal and it was quiet all the time for a little while and is quiet when cold currently. It's not bad except it seems that because its on the drivers side lower your stuck listening to it when it warms up some. Mine has cleared up but, seems louder than other cars and louder than the right side lower.
Harold
toolman 08-13-2004 10:27 AM
That is the same side I have a problem with, drivers side lower. The new parts didn't help much harold?
blackbird225 08-13-2004 10:39 AM
I swear its always that side. My new rocker did nothing really...
Michael
DanTheCat 08-13-2004 11:29 AM
Assuming the ticking noise is not the valve guide, is this something to worry about? My car does this too, but I haven't really worried about it too much.
Sounds like a good excuse to get some more HP with new cams to me...
Dan :)
blackbird225 08-13-2004 01:45 PM
me too
toolman 08-13-2004 02:42 PM
You guys are reading my mind, what good street cams would you go with for an 87, 3.2?
blackbird225 08-13-2004 03:18 PM
Ellifino, my car was 17 when you car was made!
Michael
hkspwrsche 08-13-2004 03:27 PM
IT's just about the same as it was now.. it sounded better for about 4 months but not totally gone but, now...uuugggghhhh..... Yeah thats the side the cat converter (or test pipe and cross over by now) are on and gets the hottest. I think thats what creates more wear on that side.
Harold
blackbird225 08-14-2004 09:04 AM
I dunno, my car has old skool heat exchangers, and no difference between two sides. The only thing I could think of is its further away from the oil cooler.. Thats a stretch though...
Michael ....tick.tick.tick
