-   -   CIS runs badly when warm up (http://forums.pelicanparts.com/porsche-911-technical-forum/177311-cis-runs-badly-when-warm-up.html)
Thack 08-12-2004 12:37 PM
My 79' 911SC runs poorly when up to operating temp. I suspected the freq. valve and the sensor plate. When the car was cooled down it ran well but when warm I have to pump the gas and floor it to get it to run, then it only runs well above 4K RPM. Should I look now at the WUR?
Mike
Otto 08-12-2004 01:55 PM
cis
There has to be someone in your area that has a set of fuel pressure guages that can test the fuel pressure both hot or cold. It sounds like a chech valve problem.
enolam 08-12-2004 02:00 PM
If you're going to try to deal with it yourself you MUST have CIS test guages. Otherwise youl'll be replacing the wrong parts. It's the best investment you can make.
enolam 08-12-2004 02:01 PM
Forgot to mention that you'll also need a Bosch CIS book.
Paulporsche 08-12-2004 02:08 PM
Sounds like the WUR. You can check the warm control pressure w/ the gauges the others have mentioned.
