-   -   Oil temp sending unit for 1967 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/177313-oil-temp-sending-unit-1967-911-a.html)
blau911 08-12-2004 01:03 PM
Guys,
Can anyone tell me if there is a difference between the early oil temp sending units for the SWB cars versus the sending units for the early lwb 911`s.
I have a numbered temp gauge which seems to function normally until it reaches around 160-180 fahrenheit before it starts jumping way up and back down. At operating tempereature, It will sometimes go down when I accelerate, and then level back up when I lay off the accelerator. Can I assume that its the sending unit.? If so, anyone know where I can buy a new one?
Pelican has oil temperature sending units listed for sale on their site but they only list them for model years after 1968.
dooop 08-16-2004 06:32 AM
Hi there,
I had the exact same problem that you describes with my SWB 68T.
At cold start, my oil temp reach max level, lowering as I drive, to the min.
I wanted to change my oil temp sending unit, but I found it Waaaay too much expensive (approx $200 compared to the $20 for the 69 sending unit so YES, they are different).
I then decided to change both sending unit and gauge, for a later oil temp - pressure combi (option fot 68 T models).
Change done (easy), and perfect reading since.
Hope this helps...
Dooop
blau911 08-16-2004 08:09 AM
Doop.
Thanks for the suggestion. However, my gauge faces are the early SWB green lettered ones with the chrome bezels. The 68 models went to white lettering. If I changed to a later style, I would have to change them all. Would rather stick with my originals.
Regards
blau911 08-17-2004 12:39 PM
bump
