-   -   Can I replace Speedo Drive seals in car? (http://forums.pelicanparts.com/porsche-911-technical-forum/177488-can-i-replace-speedo-drive-seals-car.html)
Jim Chambers 08-13-2004 01:33 PM
My 66 911 tranny is losing oil and it is not from the shift rod seal. Gear oil drips from the bottom of the trans support bracket. It appears wet around the speedo angle drive. I think there are two seals in there. Is it possible to remove the drive with everything in place? There appears to be very little clearance above the trans support bracket. I suppose I could support the engine/trans and revove the bracket. Any advice appreciated.
john walker's workshop 08-13-2004 01:47 PM
drain gear oil, support trans, remove trans mount, unscrew cable from drive, remove setscrew/bolt, twist out drive assembly. separate two sections and replace inner radial seal. (an aluminum retainer ring over the seal pops out easily. the other seal is an outer o-ring.
Jim Chambers 08-13-2004 01:59 PM
Exactly the help I needed. Thank you very much.
Cordts 02-27-2007 12:27 PM
HEY JOHN W.
Ok, so that aluminum retainer pops out easily,, what is the method.. Im worried tht Im about to deform it beyond use,, hasnt happened yet,, but it is in there
Cordts 02-28-2007 07:01 AM
finally got that cover off.. it was really pressed in,, no leaks now..
