CBRacerX's Avatar
993 VarioRam O2 sensor details
Greetings,
I'm getting close to the install of my 964 Engine with VarioRam intake and electronics. I am using a Euro RS 3.8 DME Harness, and it doesn't have the O2 sensor wiring built it. Does anyone have access to the wiring diagram for the 1996 993? I need to know which pin on the DME Harness (at the DME itself) receives the O2 sensor output, and it would be great to know which pin on the DME harness "body" connector provides the Belt-Minder output (and if this a positive or negative when the belt minder is triggered).
Thanks for the assistance, this is finally becoming a reality!
Chris Brown
'87 911 getting 90 964 Engine with '98 Euro VarioRam Intake and Electronics
Old 08-15-2004, 08:38 PM
