[Turn signal switch] Where does this wire go?
I'm almost done with installing my new turn signal switch. I used great caution when installing the wires on the headlight on/off switch by taking one wire off, putting the new wire on before going to the next wire.
However, do you think I can remember where this last wire attaches? No, I cannot! It is a brown wire, and it looks like it comes from the wiper switch on the RH side of the steering column. I assume it is a ground wire, and attaches to the metal "frame work" that hold the clam shell covers around the steering column. I have attached two pictures. Maybe somebody could show a picture of theirs assembled? It would help out a ton! THANKS!!! http://forums.pelicanparts.com/uploa...1092699507.jpg http://forums.pelicanparts.com/uploa...1092699620.jpg |
to ground, on the lower right screw hole in the picture. put the upper and lower plastic housings on first.
| All times are GMT -8. The time now is 12:07 PM. |
