-   -   Which Way ICV? (http://forums.pelicanparts.com/porsche-911-technical-forum/177984-way-icv.html)
North Coast Cab 08-16-2004 05:52 PM
Which Way ICV?
Took the ICV off to clean and forgot which way the arrow should point.
John
curiousone940 08-16-2004 06:28 PM
The arrow points in the direction of the airflow, which as I recall should be pointing downward toward the engine.
kqw 08-16-2004 06:33 PM
Arrow Down......
Por_sha911 08-16-2004 09:44 PM
Quick Question: after cleaning does it rattle when you shake it (like a can of spray paint). Mine clicks but doesn't rattle (need further cleaning?)
North Coast Cab 08-17-2004 07:19 AM
Joe,
If I shake it really hard to will rattle a little. Not sure if this is enough. I'm going to clean or soak thoroughly and try again. It;s worth a little effort to save the $159 for a new one.
John
Jeff 08-17-2004 07:40 AM
You can carefully pry the tabs on the side up and take it apart for further inspection / cleaning. Make sure you make orientation marks before disassemble. It will change the resistance at the plug (and not work correctly) if not assembled in the same orientation.
curiousone940 08-17-2004 07:55 AM
Connect your ICV to a 12V
curiousone940 08-17-2004 07:57 AM
As I was saying, connect your ICV to a 12V source and you should get a brief clicking sound as the valve opens up for just a split second. Use carb cleaner liberally (let it soak for awhile), then some compressed air to clean out the mess.
North Coast Cab 08-17-2004 08:12 AM
It looks like there is a screw hole on the end, though there is no head on it. Is this for disassembly? I've been liberally spraying with carb cleaner and shaking like crazy. If it doesn't work I guess I have nothing to lose taking it apart.
John
