Detached Member
Hugh R's Avatar
Question A/C Vacuum Pump Question
Anyone have any thoughts on this Mastercool vacuum pump, which is air powered. Its cheap about $50, and I only plan on doiing this kind of work once in a blue moon. My compressor easily has the needed capacity.
Here's the link http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=223
Hugh
Old 08-23-2004, 07:30 AM
david914's Avatar
My $0.02... I would get a "real" vacuum pump as opposed to the air compressor driven style. I haven't heard any good things about the venturi-style vacuum pumps. For starters, your compressor will have to run pretty steady for the 2 or so hours that you'll want to pull a vacuum. For another, I haven't heard of anyone that was able to get as good a draw with a venturi type pump (not as much vacuum). Again, just my 2 cents worth.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-23-2004, 08:04 AM
Senior Member
Hugh,
Totally agree with David. I found a good used vacuum pump on Ebay for $75 or so and it works very well.
The idea of having my air compressor run for hours at an end is not something that I want to have, so the choice was easy. These "quick and dirty" tools usually do not ever work as good as they are touted and in the end would cost you more money and time than doing it right the first time.
JoeA
Old 08-23-2004, 08:07 AM
Get a real one and then loan it to your friends and have them also buy a quality tool the group needs. This is what my circle of Porsche friends do. Cheers, Jim
Old 08-23-2004, 09:32 AM
Gasoline User
1974carrera's Avatar
If you want a no-cost alternative just use a compressor salvaged from a refrigerator or freezer. Solder the appropriate fitting onto the copper intake line of the compressor to hook your hose up to. Then carefully bend the discharge line of the compressor into a couple of loops so the compressor oil doesn't blow out. Voila, you now have a great vacuum pump!
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 08-23-2004, 09:43 AM
Here's some detailed instructions on the conversion: http://www.sas.org/E-Bulletin/2003-12-12/labNotesAS/body.html
A trip to you town's recycling station should yield lots of potential donors.
You can also use an auto A/C compressor and electric motor in a similar way.
Warren & Ron, may you rest in Peace.
Old 08-23-2004, 09:48 AM
the refrig May be doable.. it really doesn't do the correct job.. That said I know plenty of guys who did this years ago.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2004, 06:42 PM
scottb's Avatar
Hugh:
I got a Harbor Freight ad in the mail today. They have their version of that pump on sale for $9.99. It's "Lot. No. 3952." If you're going to try that style pump, don't waste your money on the Mastercool.
You'll probably be able to score this one for in the $75 range. I'll borrow it from you and give you a few bucks to defray the cost!
My $.02, FWIW.
1984 Targa
Old 08-23-2004, 10:05 PM
I'm w/ Jim on this one.
I think we have a doctor around someplace?
I kinda remember some connection to Oregun?
It's not Superman.
I'll remember soon.
anyway he shoud grap a lab vacuum unit from maintence repair and then the rest is easy.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2004, 10:22 PM
scottb's Avatar
What's the minimum HP vacuum pump for a/c work? Will 1/4 HP do?
1984 Targa
Old 08-23-2004, 10:46 PM
my non pro opnion.
a lab 1/4hp will need about 8hrs if it was my car. Then it'll be squeaky clean inside.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2004, 11:20 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Go to the local tool rental place. I rented one for $35 for the day.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 08-24-2004, 06:54 AM
Detached Member
Hugh R's Avatar
ScottB--I'll try bidding on that one you showed me. Several rental places I called don't rent them. Even at 435/day, a less than $100 used from ebay may make sense. I'll let you know if I get one, and if I do, it will be available for beer rental in the Los Angeles area. Same with gauges which I'm definitely going to buy.
Hugh
Old 08-24-2004, 07:41 AM
Senior Member
Hugh,
If you use any tool twice a year, its cheaper and better to buy it most of the time. In this case you will also find a lot of new friends so IMHO its worth it!
JoeA
Old 08-24-2004, 07:53 AM
jdowty3's Avatar
You can get the same type at Harbor Freight for $15.
If you have an Autozone in your area, they have a Tool Loaner program and you can "borrow" a real vacuum pump. All you do is leave a $200 deposit and you get it back when the pump is returned.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-24-2004, 08:09 AM
