Exclamation Engine / Trans Removal - Speedo Cable
Apologies about the repost but the engine / trans combination on my 72T is coming out this morning, the right way or the wrong way.
Can anyone tell me if there is a trick to removing what I think is the speedo cable socket-like nut? I am assuming the cable itself cannot unscrew & I must remove this large nut.
Correctamundo or no?
TIA
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 08-21-2004, 06:17 AM
fancytown
No trick, just finding the right wrench to get in there. A smaller pair of channel locks worked for me. Being aluminum and a fine thread, it might have a little corrosion on the threads making this difficult. I think it might be the same size as one of the oil line wrenches, if you bought the entire set Pelican sells. I can't quite remember, but I may have used that initially to remove it. But now, channel locks work fine.
But you are correct, the speedo cable doesn't come off until you remove this.
all cars sold.
Old 08-21-2004, 07:25 AM
This nut appears to be plated steel, anout 2 inches tall, round at the mating surface end, hex on the other.
Oh well, I guess it has to come off regardless.
Thanks,
Bill
Triplesn8s
Old 08-21-2004, 08:01 AM
fancytown
Yep, it's hollow on the round portion, and I do believe aluminum, so don't crush the round part. Just get a good grip on the hex.
all cars sold.
Old 08-21-2004, 09:03 AM
Randy Webb's Avatar
support the trans and remove the bracket - you will have plenty of room
Old 08-21-2004, 10:24 AM
Thanks Guys. Mission Accomplished.
Man, these motors sure are bulky for just 2.4 liters. They don't look nearly so big when in the car.
Bill
Triplesn8s
Old 08-21-2004, 08:46 PM
Randy Webb's Avatar
That's why you should drop in a 3.8L.....
Old 08-21-2004, 09:02 PM
