-   -   '70T engine number (http://forums.pelicanparts.com/porsche-911-technical-forum/178852-70t-engine-number.html)
dkm_chgo 08-22-2004 06:54 AM
'70T engine number
Hi,
I just bought a 1970 911T Targa with a VIN #9110112515 and an engine number of 901 106101 5R. Can anyone tell me if this VIN and engine are correct? If not, is it a T engine, E engine, or S and what production year? Thanks.
dkm
andrew15 08-22-2004 07:15 AM
The VIN number shows that it's a 1970 911T
The engine # you gave though looks like a casting #
The real engine ID #s are stamped near the fan housing support on the right side of the engine (see below pic)
Regards,
Andrew M
http://forums.pelicanparts.com/uploa...1093184101.jpg
dkm_chgo 08-22-2004 07:28 AM
Hi,
Thanks for the info, but is there any disassembly needed in order to read the numbers?
andrew15 08-22-2004 08:02 AM
nope - just take a look at the base of the fan on the RIGHT hand side - the upright where the fan housing mounts should show the engine serial #
Regards,
Andrew M
Early_S_Man 08-22-2004 09:46 AM
Make that the RIGHT hand side of the fan housing support ... looking at the engine as it sits in the engine bay!
You will probably need a good cleaning rag to wipe off the dust and dirt over the engine 'Type Number' ...
andrew15 08-22-2004 10:09 AM
Whoops - the Other Left!!! - It's on the right side as Warren points out - I'm going to plead hangover from last night....
AM
dkm_chgo 08-22-2004 04:04 PM
Hi,
Thanks for the info...The engine number is 6117859 and the engine type number is 911707 or 911/07, I couldn't quite make out the fourth number/character from the left. Thanks.
dkm
andrew15 08-22-2004 04:19 PM
Engine Type 911/07 is a 2.2L 911T (USA)
Engine # 6117859 looks to be a 1971 motor (610xxxx were 1970 911T)
If it is a 1971 version engine, it's a good find as they had piston oil squirters.
Regards,
Andrew M
dkm_chgo 08-22-2004 04:37 PM
Thanks, Andrew
