Center Cap Preferences? pix
Which center caps do you guys prefer? The all black are the stock ones, and the others are laminates (stickers) applied to the cap - just wanted to see what they looked like on my car but can't really tell.
Are your colored preferences painted or inlaid crest?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
# 2
X/A |
I prefer the monochrome look.
But more importantly whats with the weights on the outside of the rim? |
The weights are my local P-car wrench's (yes he does specialize in Porsche's) solution. I was less than thrilled, but I need new tires and am debating if I go back to him to mount the new tires.
I like #1. The weights on the outside are fine, I would just be concerned with the number of weights used.
68 911L |
19 years and 17k posts...
I like #2
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Recreational User
#1
I have #1 (PO)but prefer #2
Number TWO
80 930 67 Triumph TR4a irs 72 DeTomaso Pantera 75 911 3.3 Turbo Cab*SOLD 5-11-04 73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco |
Seems like everyone's split! That's just about sums up my sentiments.
temo - just like me, I typically prefer the option I don't have!
add some black to #1 but keep both sets -- rotate them periodically (when you change the color of your valve covers)
Most new tires are marked from the factory with a dot to indicate the heavy spot in the tire and the lighter end of the tire. The light end should line up with the stem. If your tire requires a lot of weight it can be rotated sometimes to compensate. New it's easy... if they know how it works.
Some people leave weight on and just add more if they are really dim witted. Balancing with weight on both sides is much more accurate but, static (inside only) is fine for under 100mph. Bridgestone has patented technology in the last few years that has improved the balance. One of the few companies to patent anything in the last 20! Harold
Harold
My preference is definitely #2, but I'm biased
![]() vesnyder & temo79 - I can solve your dilemma. Click on my signature line for hand painted center caps.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
I HAD number 2, but some bas^%ard stole them...
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
