vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Center Cap Preferences? pix
Which center caps do you guys prefer? The all black are the stock ones, and the others are laminates (stickers) applied to the cap - just wanted to see what they looked like on my car but can't really tell.
Are your colored preferences painted or inlaid crest?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 08-20-2004, 08:52 AM
Yellowbird RS's Avatar
# 2
X/A
Old 08-20-2004, 08:55 AM
I prefer the monochrome look.
But more importantly whats with the weights on the outside of the rim?
Old 08-20-2004, 09:25 AM
vesnyder's Avatar
The weights are my local P-car wrench's (yes he does specialize in Porsche's) solution. I was less than thrilled, but I need new tires and am debating if I go back to him to mount the new tires.
Vance
Old 08-20-2004, 10:02 AM
B D B D is offline
B D's Avatar
I like #1. The weights on the outside are fine, I would just be concerned with the number of weights used.
68 911L
Old 08-20-2004, 10:06 AM
19 years and 17k posts...
azasadny's Avatar
I like #2
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-20-2004, 11:34 AM
Recreational User
porschenut's Avatar
#1
Old 08-20-2004, 12:40 PM
temo79's Avatar
I have #1 (PO)but prefer #2
Old 08-20-2004, 12:49 PM
75'930cab's Avatar
Number TWO
67 Triumph TR4a irs
72 DeTomaso Pantera
75 911 3.3 Turbo Cab*SOLD 5-11-04
73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco
Old 08-20-2004, 12:57 PM
vesnyder's Avatar
Seems like everyone's split! That's just about sums up my sentiments.
temo - just like me, I typically prefer the option I don't have!
Vance
Old 08-20-2004, 02:11 PM
Randy Webb's Avatar
add some black to #1 but keep both sets -- rotate them periodically (when you change the color of your valve covers)
Old 08-20-2004, 06:23 PM
hkspwrsche's Avatar
Most new tires are marked from the factory with a dot to indicate the heavy spot in the tire and the lighter end of the tire. The light end should line up with the stem. If your tire requires a lot of weight it can be rotated sometimes to compensate. New it's easy... if they know how it works.
Some people leave weight on and just add more if they are really dim witted. Balancing with weight on both sides is much more accurate but, static (inside only) is fine for under 100mph. Bridgestone has patented technology in the last few years that has improved the balance. One of the few companies to patent anything in the last 20!
Harold
Harold
Old 08-20-2004, 06:52 PM
steve911's Avatar
My preference is definitely #2, but I'm biased
vesnyder & temo79 - I can solve your dilemma. Click on my signature line for hand painted center caps.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 08-23-2004, 12:38 PM
lateapex911's Avatar
I HAD number 2, but some bas^%ard stole them...
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 08-23-2004, 07:06 PM
