Phoenix's Avatar
$2,500 and winter brake & suspension project plans
My longer term plan is to put a 2.7 RS spec motor in Phoenix by either building it myself or having it done (time, tool and patience issues). Although I had hoped to do this sooner rather than later, the reality is that it will take me over a year before I can serisously tackle this (financial issues).
In the interim, I'd like to address the "light and twitchy" feeling in the steering/ suspension feels and do something to minimize the brake fade felt during my last trip to Lime Rock.
If you had around $2,500 to spend on parts, what would you do?
Here's what I have now:
Suspension: turbo tie-rods and the original front and rear sway bars. As far as I can tell, no bushings have ever been replaced on the car.
Brakes: I have the original T calipers with relatively new pad, stainless steel lines and drilled rotors (about 8,000 miles and 3 driver's ed events on them). There is a very noticible pulsing when I brake under light loads, this is gone under heavy braking.
I'd love to hear your thoughts.... Oliver
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 08-23-2004, 09:52 AM
I would rather be driving
jpnovak's Avatar
I would go for a used Carrera brakeset and rotors, cooling ducts and good pads.
Then spend a chunk of change on seat time.
Then I would rebuild the entire suspension. Poly bushings are cheaper but will require more fit. Chuck's Elephant Racing bushings are very nice. then upgrade to larger torsion bars, 21/27 or 22/28.
All of these parts will be well within your budget, require a weekend to install and will increase the fun factor at the track while solving your problems.
Old 08-23-2004, 09:58 AM
efhughes3's Avatar
I'd rebuild the suspension with Elephant bushings and new ball joints. Not hop it up, just redo it right. Then, I think seat time would be more beneficial as the car would be in good shape. Along with the brake job and turbo tie-rods and wheel bearings, of course.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-23-2004, 05:49 PM
jmz jmz is online now
jmz's Avatar
carrera brake job obviously means new struts w/ the 3.5" strut spacing.
I am in the process of a susp. re-do myself. I should know in a couple weeks how it turns out.
basically for me, new struts, inserts, rear shocks, t-bars, elephant bushings, wheel bearings (fr and rear) carrera calipers w/ frozen slotted rotors, and ball joints.
struts/ shocks are HD/Sport combo. T-bars are 21 & 27 sanders bars.
...sway bars later, I am dreaming of SRP or Elephant Racing super trick sway bars.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 08-23-2004, 05:55 PM
