Detached Member
Anyone have any thoughts on this Mastercool vacuum pump, which is air powered. Its cheap about $50, and I only plan on doiing this kind of work once in a blue moon. My compressor easily has the needed capacity.
Here's the link http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=223
Hugh |
My $0.02... I would get a "real" vacuum pump as opposed to the air compressor driven style. I haven't heard any good things about the venturi-style vacuum pumps. For starters, your compressor will have to run pretty steady for the 2 or so hours that you'll want to pull a vacuum. For another, I haven't heard of anyone that was able to get as good a draw with a venturi type pump (not as much vacuum). Again, just my 2 cents worth.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Senior Member
Hugh,
Totally agree with David. I found a good used vacuum pump on Ebay for $75 or so and it works very well. The idea of having my air compressor run for hours at an end is not something that I want to have, so the choice was easy. These "quick and dirty" tools usually do not ever work as good as they are touted and in the end would cost you more money and time than doing it right the first time. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Get a real one and then loan it to your friends and have them also buy a quality tool the group needs. This is what my circle of Porsche friends do. Cheers, Jim
Gasoline User
If you want a no-cost alternative just use a compressor salvaged from a refrigerator or freezer. Solder the appropriate fitting onto the copper intake line of the compressor to hook your hose up to. Then carefully bend the discharge line of the compressor into a couple of loops so the compressor oil doesn't blow out. Voila, you now have a great vacuum pump!
Bob V 1974 911 Carrera coupe Grand-Prix-weiß 1977 930 turbo Carrera coupe Hellgelb 2018 Cayenne turbo Schwarz 2019 911 GT3 RS Schwarz |
Here's some detailed instructions on the conversion: http://www.sas.org/E-Bulletin/2003-12-12/labNotesAS/body.html
A trip to you town's recycling station should yield lots of potential donors. You can also use an auto A/C compressor and electric motor in a similar way.
Warren & Ron, may you rest in Peace. Last edited by RickM; 08-23-2004 at 09:57 AM.. |
the refrig May be doable.. it really doesn't do the correct job.. That said I know plenty of guys who did this years ago.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hugh:
I got a Harbor Freight ad in the mail today. They have their version of that pump on sale for $9.99. It's "Lot. No. 3952." If you're going to try that style pump, don't waste your money on the Mastercool. You'll probably be able to score My $.02, FWIW.
1984 Targa Last edited by scottb; 08-23-2004 at 10:33 PM.. |
I think we have a doctor around someplace? I kinda remember some connection to Oregun? It's not Superman. I'll remember soon. anyway he shoud grap a lab vacuum unit from maintence repair and then the rest is easy.
What's the minimum HP vacuum pump for a/c work? Will 1/4 HP do?
1984 Targa |
a lab 1/4hp will need about 8hrs if it was my car. Then it'll be squeaky clean inside.
Unoffended by naked girls
Go to the local tool rental place. I rented one for $35 for the day.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Detached Member
ScottB--I'll try bidding on that one you showed me. Several rental places I called don't rent them. Even at 435/day, a less than $100 used from ebay may make sense. I'll let you know if I get one, and if I do, it will be available for beer rental in the Los Angeles area. Same with gauges which I'm definitely going to buy.
Hugh Last edited by Hugh R; 08-24-2004 at 07:46 AM.. |
Senior Member
Hugh,
If you use any tool twice a year, its cheaper and better to buy it most of the time. In this case you will also find a lot of new friends so IMHO its worth it! JoeA
You can get the same type at Harbor Freight for $15.
If you have an Autozone in your area, they have a Tool Loaner program and you can "borrow" a real vacuum pump. All you do is leave a $200 deposit and you get it back when the pump is returned.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
